dead battery! sort term fix!!!
ok have you ever got up in the morning and poped in the car & dam car wont start well i have a little (mickey mouse)= short term fix. that will get you on your way!
the answer is red wine!!! here is a little clip that explain every thing =D
i saved your day!
http://www.metacafe.com/watch/703646..._charged_with/
p.s. i also herd dropping 2 aspirin in your battery cell works too.
tell me what you think!
make that coin!
i saved your day!
make that coin!
i saved your day!
make that coin!
i saved your day!
make that coin!
thats pretty nuts..
wonder if leaving the wine in the battery is bad for it or not.. thats sweet now i can tell people that i see drinkin red wine that they are drinking battery acid in a sense
Registered User
the wine will definately corrode the plates makin electron transfer virtually impossible
try pushing the car to a good speed, on first gear then 2 stepping, it will get the car alive for a short term and the car will stay on using the dynamo, try to be hasty because stopping for so long can let your car die again, going faster helps the dynamo do its job.
EvolutionRacing
Jul 20, 2016 02:06 PM
