Tranny oil/fluid
If you search, you'll find a how to for changing the tranny fluid. I did mine awhile back and it's relatively easy. Just make sure you buy the right fluid.
I use Mitsu fluid and they're like $80 for a gallon I think. Some will recommend Redline, and stuff like that.
But it's just 1 bolt to drain. Then you open another bolt to fill. Unless you can measure the right amount to fill, I just fill until fluid start to come out of the fill hole. It's relatively simple.
