Misfiring after spark plug install. Help!!!
I just put in new spark plugs, and my car started misfiring when i first started it up, so i put the old spark plugs back in and now the car is still misfiring. I used NGK Iridium plugs to. I reset the ECU and checked if all the spark plugs are working, they are. Everything seems to be fine. But the car misfires and i don't know what to do.
HELP!!!
The car ran fine before i did this and now it is misfiring like crazy.
Thanks
HELP!!!
Thanks
Same exact thing happened to me. I even tried changing the gap (wider and shorter). Replacing the old plugs didn't help either; still misfired. It ended up being the coil packs that blew. Replaced the wires too. Why in the world would they just blow at that time though? I still don't know. Make sure you didn't plug the wires back in in the wrong order though. (The Firing order is 1-3-4-2)
I think there was a process error with.
Does anyone have a successful known process.
could you clarify?
guapoholic
24
Feb 24, 2017 07:47 PM
35rEvosilver
Oct 24, 2011 06:02 PM
