Need Help: Battery (+) cable to trunk on Evo9
Hi,
i need some help. just bought a new amplifier. But i have no idea how to get the positive (+) battery cable into the trunk/inside of the car. Can somebody please help me?
thanks a lot and greets from germany!
Alex
Alex
See if you can get it through the firewall through a factory grommet. I routed mine across the engine bay to the passenger side and through a factory grommet. It looks much cleaner than running it over the front fender. Ill admit that getting it through a grommet is a PITA but the end result will be worth it!
I Ran My + From the batt under the sway bar to the pass side down and under the car and throught the frame and into the passenger side floor board where your feet rest. Then into the side pannels and into the trunk under the rear seat. Vary easy to do took me a little over a hour to install a whole system from headunit back. My ground go's from the amp to a bolt in the trunk!
Just pull back the carpet for the passenger foor rest and there will be a plug just cut it and run the wire through it and after installing it all I cant even tell there is a whire there no bumps and I have 0 wire.
