o2 anti fowler.. Anyone know how to make one!
ok i here about this spark plug anti fowler that u can use for your o2 to raise it enough so there is no check engine light anyone know how to do this!
did you look at the pics? they sell them at autozone or orielly's you have to take your o2 sensor bolt out from under the car (under the shifter to be close) and drill>connect>and restart your ecu (disconnect battery and step on brakes) the connect it back and whala
^ dont remember the correct size but that may be right. Then take that and drill it out with a 1/2in bit i believe. You will know if its drilled out enough if the o2 sensor fits in in. Its pretty self explanatory. You will figure it out
18mm is alittle loose it will get to a point of it being tight then get loose now if you get it up to that point and stop then your cool i would say get 19mm if they have them where you live we only had 18mm so i used that one got a nice write up on my website if you like
http://www.cardomain.com/ride/3123213/4
