i messed up! rotor/pad replacement
i was good all the way up to i got to the point where i was placing the new set of brake pads back on. the little things that push the brake pads onto the rotors were out too far and couldn't push both of them in?
so i figured it could be the eBrake on. took that off same ****. so instead i decided to pump the brakes. well the **** just kept going FURTHER AND FURTHER. so i decided hey maybe cause they are looking for something to push on it may just need to be taken off and then push the brakes to compress the **** back in. (which one side did and the other side kept going outwards.
here it goes: one of the little ****s popped out of the rubber and can't get it back in and the other one looks like it has the potential of popping out as well.
WHAT THE F*ck CAN I DO!?!!!! THE LITTLE METAL PIECE IS OUT AND CAN'T PUT IT BACK IN AND THE OTHER ONE LOOKS LIKE IT'S ABOUT TO POP OUT!!!
ill post a picture next of the little metal circular piece i am referring too in the next post!
you need a clamp. Pull the cap of the brake booster if not you will build pressure up in the lines and not be able to push the pistion on. Once you have done that take the clamp and turn it down this will push the piston in. Hope that helped you out
Or get an actual piston clamp like the above said, then you can push all the pistons in at the same time. Pulling the cap off the brake fluid resevoir (brake booster) is not typically needed, but will also help. I never did that (and never have) and never had a problem on all 3 of my cars, a bit of fluid would leak out of that caliper is all.
i have help coming tomorrow thanks for all the information. i should have read it over 1000x more times i'm not blaming anyone but my own fault. but i don't need **** for it. i dont have the money during a recession to pay 760$ to have rotors/pads changed.
Wait, you were doing the pads AND rotors? Why? Were the rotors really bad? That job is much more complicated thann just pads (though, still not bad). 760 for 4 new pads, 4 new rotors, and install is not that bad of a price. 2 hrs of labor ~ 200, 4 decent pads ~300, 4 new rotors... easily over that remaining 260. Unless you got cheapo blanks like I did, but still that adds up to 210 (70 per rotor) and that's 710 dollars.
760 for pads+install, that's awful. More like 300 for pads, done. And then if you have somewhere do it, maybe 75-150 for install of the pads. Was the 760 a quote from a dealer?
