Evo IX SE - Aftermarket Headunit in Upper Din
I'm going to be installing an aftermarket headunit into the stock location.
I've seen threads mention bypassing the stock AMP for the system.
Is this necessary on the SE's or only the GSR's with SSL?
I'm new to evo's and I haven't been able to find a definitive answer.
Thanks in advance.
-Nic
Thanks in advance.
-Nic
1 Post
Im pretty sure thats only if you have the ssl package. I don't believe I have an amp in mine... I have an 06 MR. Don't know if I have the ssl package or not. The easiest way to install it is to just go to an electronics store that does installs (ie. Fry's, best buy, etc.) and ask for a radio hookup harness for your evo. Then all you have to do is wire that harness to the harness that comes with the head unit, plug em in, and go. Its really easy, all the wires are color coded.
DSMEVOLUTION
Jun 6, 2007 07:52 PM
Shaitiger
Sep 24, 2005 01:26 PM
