Removing evo VIII car seat
How do you remove evo VIII car seat without taking off the bracket. Removing only the slider and the seat. I was having a tought time unbolting the Hex type bolt off the seat last night and still couldn't loosing the bolt. How do you pro's do it?
Not quite following you. there is four bolts that fasten the seat to the floor. two in the front two in the rear. Driver rear is under a plastic cover and the other is under the arm rest.
That's the bolt I tried not to loosen. Instead if you look at the slider itself you'll see the hex bolt bolted down to the crackers that u mentioned earlier.
barneyb
May 13, 2018 08:24 PM
Gas'd LanOZ
Lancer How Tos / Installations
Feb 27, 2004 10:01 PM
