Help, low idle/stalling!!!!
Old Jul 23, 2010 | 03:22 PM
XSboosyed10's Avatar
First off I have a 03 evo, hks 264 cams, injen air intake, greddy rz bov, injen uicp, owner had the car tuned by david buschur.
When coming to a stop, this morning at a red light it just died, and will not keep idling, it will just die. I also have noticed a loud tick, coming from the injectors. I know its the injectors because you can feel them ticking. After you take off it runs normal, boost is the same. If I set there and mess with it at idle I can get it to idle steadily but at like 500-600 rpms. I have taken the plugs out and they are fine, checked all connectors and wires, no CEL.
How/where do I start troubleshooting this?
Old Jul 23, 2010 | 03:24 PM
MR BURTON69's Avatar
A similar thing happened to a friend, he had the idle control sensor on the throttle body go out.
JP EVO X's Avatar
A/C off or on?
Old Jul 23, 2010 | 03:25 PM
A/C is off. How can I test the ISC?
Old Jul 23, 2010 | 03:31 PM
One of the local evo guys helped my friend test the ISC, he took it out and checked the resistance with a multi meter and it wasnt in the correct parameters. Im not sure the exact numbers, you could pm him on here his screen name is gear head. He is way helpful.
Old Jul 23, 2010 | 03:34 PM
I have the FSM up right looking through it, if that does not help I'll hit him up. Thanks alot.
Old Jul 23, 2010 | 04:48 PM
OK, fixed the problem. After all it was a cheap fix. I took an unhooked the battery, all the connectors in the car and used crc electrical contact cleaner to clean all of them. Car idles like it should again. Guess it was bad contact on the ISC connector. CRC ftw!!
Old Jul 28, 2010 | 12:50 AM
4g63Moon's Avatar
I thought it would be the bov if u had the vta set up? haha i was wayy out of the league lol
Old Aug 7, 2010 | 07:31 PM
whitesnake's Avatar
Ok what is the ISC connecter cuz my car is having same problem
KJS
Oct 4, 2016 07:58 AM
zenkisilvia
Nov 15, 2013 02:14 AM
iStubz
Oct 8, 2013 12:15 AM
dozena
Mar 10, 2013 02:02 PM
FiftyFive
17
Jan 5, 2008 01:07 PM
Quick Reply: Help, low idle/stalling!!!!
