Aftermarket Radio Install in Infinity System
Hi Guys,
I recently installed a kenwood kvt-516 in my 8. The connections are all great, except the cable I connected from the din to the unit only had 4 outgoing cables for the front/rear speakers. The unit has two cables for the subwoofer, but my din cable connector did not.
Any ideas or a specific cable connector I'm going to need?
Current connection:
Factory DIN Cable
DIN Aftermarket Mitsubishi Connector
Rear + Rear - Front + Rear -
Kenwood kvt-516 aftermarket unit
Current connection:
Factory DIN Cable
can you send us a pic so that i can figure it out...im a little confused. In most cases the additional wires assuming their for your speakers wouldnt need to be used since you connected the wires into the stereo
The din cable from the car connects to a cable I bought at best buy that has 4 cables on it.
2 For the front speakers
2 For the rear
On the radio,
it has 6 cables
2 for the front
2 for the rear
2 for the subwoofer.
I just havn't been able to find a different cable that can hook up the din from the car to the 6 on the radio.
2 For the rear
On the radio,
it has 6 cables
2 for the front
2 for the rear
Your car doesn't have a stock subwoofer. The harness you are looking for does not exist. The harness from best buy allows low level signal out of your radio into the factory infinity amp for the speakers curently in your car. The subwoofer pre-outs on the back of the radio are for if you add subwoofers you can control them independently.
You cannot control the sub independently on the stock infinity system. Sub is powered by the same amp as the speakers. With the mitah adapter. You need you hook it up the the front outputs and rear outputs only, nothing in the sub output and all your speakers should work exactly how they did with the factory HU.
nybluelancer
Feb 11, 2017 06:43 AM
nybluelancer
Feb 9, 2017 01:41 PM
merwin
14
Jan 21, 2008 01:11 PM
zlancer
Jun 22, 2003 11:06 AM
