P0011 - cam sensor removal, check, and proper install? Need to rotate 180*???
Old Feb 16, 2011 | 12:23 PM
atxMR's Avatar
I'm throwing the P0011 code so I pulled the cover to my cam sensor to see if I could tell if the sensor was installed 180* out when the cams were done. However, now that I have the sensor cover off I am unsure of how to properly pull the sensor. Can somebody who has dealt with this before please give me a step by step on what I need to do here? I pulled the 2 bolts at the base of the sensor, but it appears that I may have to pull the valve cover as well. Is this the case?
I've searched the other threads on this issue and didn't find a clear how-to on properly installing the cam sensors.
Thanks
Also, FWIW I've already pulled the cam gear cover to check that the timing marks are aligned properly.
Old Feb 17, 2011 | 11:20 PM
selp's Avatar
ive had the p0011 code for over 2 years..
I finally bought a new intake cam sensor and I hope that will fix the problem.
the intake cam sensor only installs one way, I dont know how people can get this 180*
I will let you know what I do ..
if you find out about anything let me know
Old Feb 24, 2011 | 06:25 PM
atxMR's Avatar
Originally Posted by JohnBradley
P0011 is MIVEC slow to respond. Look for a clogged feed solenoid or low oil pressure. Mitsu will throw a P0365 if its out of range or over advanced normally. 0011 is almost never the over advanced in the "normal" OBD designation.
http://www.obd-codes.com/p0011
Generally system performance
Here's another possible solution. I've yet to have the time to work on the car...I've got to figure out where the oil feed solenoid is located first.
Sheasta
Jun 20, 2016 01:38 PM
Sheasta
Sep 27, 2015 08:52 PM
CeliOnce
Sep 14, 2015 06:55 PM
atxMR
12
Oct 15, 2014 08:00 PM
mick82907
Feb 2, 2009 09:32 AM
