Transmission reinstall tips need
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
So I've been trying to get my transmission back in after doing a clutch job on jack stands. This is my second time doing it, first time it was easy, but for some reason I'm struggling this time around to get the transmission back on. So I thought I'd ask for some tips while I'm sitting here waiting for the rain to stop. Thanks in advance
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
If its just trouble getting lined up on splines of the shaft of the transmission, we had one friend hold up the trans and rock back and fourth as another person was sitting on the floor underneath pushing in with their legs against the trans.
This was also on a hydro tob, dont know if this helps.
Your gunna have to fight it in there, I worked on my with a buddy for a whole hour trying to wrestle it in. if you can get a tranny jack and put your trans on that and have somebody on top jiggling the tranny around while you push. It will work just might take a lil longer then you think.
IF you have an engine hoist it can help you hear. on the top of the case, near the centerline, is a cast loop with a ~1/2" dia hole in it. if you put a chain at this point and lift the gearbox, it will roughly balance it out at the appropriate angle to get it lined up perfectly with minimal effort on your part. having done a few dozen DSM gearbox drops in the past, it was nice to see that little feature there on the evo and i didn't actually notice it until my fifth or sixth evo clutch swap
when I did my clutch, my buddy and I had a jack under the engine and one under the trans, and we tried to get the angle right by using both jacks. Took us a bit of time, but it eventually went on.
Trying turning the engine over buy hand a little bit to jiggle the splines into place. Also make sure youre not installing an ACT clutch because they are garbage and you will have problems.
Had same problem with mine it took some good effort to get it on.we got it close enough to get a bolt on the top and bottom going into the block then tighten them and it sucks the tranny into position. Make sure you line up the tease swell as I had problems with it to just jiggled it into position
Try locking the trans in gear so the input shaft doesn't spin. This will help out dramatically. Also, while installing try to tilt the trans back towards the firewall and put the trans on the input shaft and then rotate the trans back to line the dowel pins up to put it on. Hope this helps.
I ended up using a motorcycle jack with a piece of 1" plywood cut to the dimensions of the 2 rests. It was nice and easy because I then bolted the plywood right to the jack and then I had one big flat area to work with sliding the tranny all around. Once I was close just had to man handle the thing and get the splines lined up while pushing. It took 3 trys to get everything lined up then was able to slide it in. It's a PITA but very do-able by yourself.
![Mad](https://www.evolutionm.net/forums/images/smilies/mad.gif)
/ rant
![Cool](https://www.evolutionm.net/forums/images/smilies/cool.gif)
What exactly is "hard". Check to see if the friction disc is aligned with the input shaft or center within the presure plate and flywheel. if its to heavey then use a jack under neath to help with the weight.
jamesinger
Dec 8, 2012 12:25 PM
back, evo, evolutionm, input, lined, mr, reinstall, shaft, tips, tranny, trans, transmision, transmission, transmisson, tricks
