help with defi oil temp and pressure sensors
hi everyone. i just bought defi oil temp and pressure gauges, but i don't have oil temp sensor, i have evo 9 mr which it comes with oil temp guages stock. can i hook up the defi oil temp gauges into stock temp sensor? or i need use defi gauge temp sensor with defi gauge. and there is 8mm bolt near the oil filter, can i hook up the oil pressure sensor into there after i remove the bolt? or i have to buy the Oil Filter Adapters. please help. thank you.
I learned the hard way waaaaay back when. If you do add a guage that comes with a sensor use the sensor supplied cause they are calabrated for that particular guage. I can't say I know about the defi guages and hooking into the filter but the best advice I could give is just read the directions and do what it asks.
you have to use the defi sensor. yes you also need the adaptor or you can buy a drain plug.
http://store.42draftdesigns.com/EVO-89_c_90.html
iLLevo_
16
Feb 19, 2017 10:30 AM
vastevo
Evo X How Tos / Installations
Apr 23, 2016 11:10 AM
awdboosted
Nov 9, 2015 06:58 AM
