Scratched Tail-lamp lenses? No Problem
This how to guide will assist you in polishing your scratched tail lamps or headlights (plastic)
Materials:
1000 Grit Wet/Dry Sandpaper
1500 Grit Wet/Dry Sandpaper
2000 Grit Wet/Dry Sandpaper
2500 Grit Wet/Dry Sandpaper
3000 Grit Wet/Dry Sandpaper
Blue Tape
Cutting Polish(I used Menzerna SIP)
Orange Buffing Pad
Rotary Polisher(DA will work too with more agressive compounds)
QD Spray/Clay lube/ONR
First have a clean surface of the lens,then mask vehicle off
Make sure Sandpaper is wet (in a bucket/container of H20)
Spray a couple of sprays down on the surface(with clay lube or QD spray)
Keep sanding starting with 1500(work with medium speed) with even pressure
After surface feels completely smooth with the lower grit #, move up a gradient, make sure both the surface and the paper are wet at all times.
Stop around 2500 grit and apply polish and attempt to polish out the scratches, marks still do appear go back with a finer grade, remember practice makes perfect....Longer time spent sanding= better end results.
Materials:
Blue Tape
Orange Buffing Pad
Mitchubishievo
Aug 30, 2008 04:10 PM
