2004 Evo RS headlight question
Yeah bro i have the headlight harness its still the factory one i didn't change nothing but the harness from the car that plugs into the headlights harness the plugs different i guess because the rs didn't come with Foglights that's what im assuming. But i was wondering maybe someone have done this before could help me out
So the HID bulbs are D2S and if you want to run those HIDs you will need something like this:
http://www.theretrofitsource.com/pro...roducts_id=244
I would recommend finding the original RS headlight harness and running aftermarket ballasts so that you can use the HIDs.
Lol i have a original set of RS headlights but i really dont like that aftermarket hids thats what i was running the whole time plus i want foglights also.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
i got all that bro the headlights set came complete but the main harness that plugs into the headlight harness its different. thats what im trying to explain its confusing. i searched every where no luck yet.
Lol i have a original set of RS headlights but i really dont like that aftermarket hids thats what i was running the whole time plus i want foglights also.![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
On the RS harness you have two connections for two bulbs. One low-beam and one high-beam connection. The high beam is the same bulb for both headlights. The low beam is different. Just use a 9006 HID bulb instead.
Yes I understand that the MR harness does not fit. You have only one choice and that is to use the RS harness.
