Replace radio antenna base?
Old Jan 10, 2013 | 08:17 PM
EvoIXPilot's Avatar
Guys. The car I have's base broke and needs replacing. Can anyone pls provide step by step? Thanks!
Old Jan 11, 2013 | 07:57 AM
llDemonll's Avatar
i believe you have to pull the headliner to get at the base of the mount
Old Jan 11, 2013 | 03:23 PM
johnnydemz4G63's Avatar
Pull headliner and remove two bolts and unplug the the antenna harness. I replaced mine with A lancer antena base. good luck
Old Jan 14, 2013 | 04:06 PM
EvoIXPilot's Avatar
Do I have to pull out the whole headliner or just the back? If just the back, remove the c pillars and what else am I supposed to remove to pull back the liner? Thanks!
Old Jan 14, 2013 | 04:21 PM
I would take off the pillars then remove partial of the headliner but you got to be careful because you can leave Bends in the headliner. then you Wedge your way in and take off the 2 nuts.
Old Jan 14, 2013 | 04:25 PM
the plug is going to be the hard part, what I did I Pulled off the wire with the pen from the antenna base harness/plug and simply used the new harness and forced the pin/ wire in it.
aamoedo
Oct 1, 2016 04:46 PM
Evoguy!123
Jun 7, 2016 09:35 AM
Bhsj13
Mid-Atlantic Region
Mar 27, 2016 08:39 AM
Jorge Fernandez
Outlander Sport
Jan 31, 2016 12:09 PM
D-Mon3y69
Jun 17, 2013 12:30 PM
Quick Reply: Replace radio antenna base?
