DIY Dual pumper AN fitting questions.
Does anyone know what -6 or -8 fittings you would use to modify the stock pump housing. I found an old write up on how to do it with barbed fittings, but not AN fittings. I know you would want to use a 90 degree -6 or -8 AN fitting for your fuel feed, depending on what power your trying to achieve. However what would you use to connect the pump to the 90 degree fitting?
Probably would want to use a 90* bulkhead fitting that has a barb adapter at the end or a dual barb. I would imagine atleast.
AKA use rubber hose to run from pump to the bulkhead fitting.
Ted B
146
Aug 12, 2015 11:45 AM
fireroasted
25
Dec 19, 2012 08:43 AM
Creamo3
12
Apr 3, 2009 04:31 PM
