ACD Relocation to DR side trunk compartment
I think the other How-tos already covered everything. I did do this just on jackstands. It's not too hard (in hind sight), just lots of factors, worrying and sourcing bits and pieces
https://www.evolutionm.net/forums/ev...elocation.html
comes off one piece with the hard line
cut the bracket, leaving just one 'hook'. the hole will need to be adjusted to match the hole already on the car's frame. the bolt is 1/2" 3" long
you can probably find better preformed hoses. i'm still figuring out how to use these butt connectors so i didnt use them
10-color 18ga wires - $24 on ebay black-red 12 ga wires - $14 on ebay
I ran the wire thru here
MicRX (Mar 1, 2023)
I wont be content until I use the EVAP hard line eventually. my current final plumbing set up is 14mm tube nut to 1/2" nut, 1/2" coupler, 1/2" nut to 1/2" nut, 1/2" coupler, 1/2" nut to 14mm nut. I have an AN6 flexible hose with 1/2" adaptors (was backup) to replace tube section 2 (in bold) temporarily since I want to redo it
Harborfreight has a good tube bender. I need to take pics of the other tubing
pre formed hoses
has stink venting and water drainage for clean ups
fired up the 3d printer (no not really). will figure out something else later. it reminds me of the waste management truck
extra tire clearance and air deflection to the intake
finally have room for a aftermarket air intake
pre formed hoses
MinusPrevious (Feb 6, 2022)
