Check Out These New Defi Advance CR Gauges!!
Old Jan 7, 2010 | 04:38 PM
Fizz Autosports's Avatar
Introducing the NEW DEFI ADVANCE CR GAUGES
PRODUCT FEATURES
- Interactive communication advanced system is implemented
- Flat glass and precise graduation scale give more needle accuracy and high visibility
- LOW mount back case (11% down over currently in use)
- Flat glass adopted
- Gauges can be controlled from distance with the included switch unit
- Opening and closing modes can be selected from 2 variations
A. Two Color Flashing Light
B. Flashing Type
- The installation of additional gauges is easy. Just connect it with the other two gauges and attach the wire to Advance Control Unit
- The illumination at night can be switched between 2 different colors
(White dial: amber red / blue; Black dial: white / amber red)
- The outer edge of the gauge illuminates in red at night
- The needle pointer driven by original stepping motor has a smooth instantaneous response to rapid acceleration of high performance vehicles
- The microcontroller calibrates up to 270 degree angle in 3027 - 4600 segments (0.088°- 0.059°), and provides accurate vehicle information
- Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit and serial communication errors
- Warning by buzzer sound when the warning LED is on (buzzer sound can be turned on / off)
A. Peak Time
B. Warning Time
- Peak value and warning value during driving are stored. Driving data can be stored and replayed up to 3 minutes
- A mounting bracket, meter cup, regular position bezel are provided with this product
- With both fuel pressure gauge and turbo installed, differential pressure can be monitored on the fuel pressure gauge screen
- Defi-Link ADVANCE SYSTEM is the next generation system that adopted the interactive communication
- The product of Defi-Link ADVANCE SYSTEM cannot be connected with the product of Defi-Link SYSTEM. It is not compatible with the product of Defi-Link SYSTEM
Here is a Link to the video so you may see how the gauge operate when turned on & turned off
http://www.youtube.com/watch?v=KZS5qbeLP60
DEFI ADVANCE CR GAUGE LINE UP
Retail Price
o 60mm TURBO 200KPA in White or Black - $283.00
o 60mm TURBO 120KPA in White or Black - $283.00
o 60mm Manifold Pressure in White or Black - $283.00
o 60mm Oil Pressure in White or Black - $324.00
o 60mm Fuel Pressure in White or Black - $324.00
o 60mm Oil Temperature in White or Black - $229.00
o 60mm Water Temperature in White or Black - $229.00
o 60mm Exhaust Temperature in White or Black - $324.00
o 60mm Tachometer 9000rpm in Black or White - $202.00
Retail Price
o 52mm TURBO 200KPA in White or Black - $283.00
o 52mm TURBO 120KPA in White or Black - $283.00
o 52mm Manifold Pressure in White or Black - $283.00
o 52mm Oil Pressure in White or Black - $324.00
o 52mm Fuel Pressure in White or Black - $324.00
o 52mm Oil Temperature in White or Black - $229.00
o 52mm Water Temperature in White or Black - $229.00
o 52mm Exhaust Temperature in White or Black - $324.00
PLEASE PM US FOR PRICING, COMBO PRICES, SHIPPED PRICES, etc.
You can paypal to paypal@fizzautosports.com or give us a call if you want to use VISA and MASTER credit card. For NY residents must add 8.875% NY SALES TAX.
Old Jan 7, 2010 | 04:39 PM
4G63K's Avatar
Do they come in 30 PSI?
Black Face and White Light?
Old Jan 8, 2010 | 08:25 AM
As of right now the gauges are being released as KPA but like the DEFI BF Imperial I am sure they are going to release them in PSI but these gauges are still brand new.
The 200KPA converted to PSI is 29psi.
Old Jan 11, 2010 | 09:10 AM
Monday Bump
Old Jan 12, 2010 | 08:07 AM
Tuesday Bump
Old Jan 12, 2010 | 08:14 AM
wizzo 8's Avatar
Nice! I would need the boost gauge to read at least 40 psi though.
Old Jan 13, 2010 | 09:55 AM
Ah Sorry but right now the highest the are offering is 30psi
Kenny@Fizz
Old Jan 14, 2010 | 08:24 AM
Thursday Bump
Old Jan 16, 2010 | 08:45 AM
Saturday Bump
Old Jan 19, 2010 | 08:20 AM
Tuesday Bump
Old Jan 20, 2010 | 09:30 AM
Wednesday Bump
Old Jan 21, 2010 | 08:46 AM
Thursday Bump
Old Jan 22, 2010 | 08:29 AM
Friday Bump
Old Jan 25, 2010 | 10:12 AM
Monday Bump
Old Jan 26, 2010 | 08:55 AM
Tuesday Bump
