*new* Innovate Motorsports MTX-L Digital Wideband O2 Kit $189.00 @ Mellon Tuning
Old Jan 14, 2011 | 01:57 PM
Mellon Racing's Avatar
*new* Innovate Motorsports MTX-L Digital Wideband O2 Kit @ Mellon Tuning
These are ready to ship! Let us know if a competitor advertises a better price and we'll do our best to match or beat it
You can order online here http://www.mellontuning.com/index.ph...roducts_id=672
ALL-IN-ONE
(Wideband Controller integrated into the MTX-L gauge housing)
The new Innovate Motorsports Digital MTX Series Air/Fuel Ratio Gauge utilizes the only 100% digital Wideband air/fuel ratio technology on the market! The award-winning patented DirectDigital™ technology we use is faster and more accurate than common “UEGO” gauges and is now more affordable! In addition, the gauge features a water resistant casing, interchangeable faceplates and bezels, and 2 fully programmable linear analog outputs for use with aftermarket engine managements systems and dataloggers!
KEY FEATURES
• The only 100% digital wideband air/fuel ratio technology!
• Water Resistant 52mm (2 1/16”) round dash-mountable casing is perfect for automotive, powersports, marine, and demanding racing applications
• Built-in Direct Digital™ Wideband Controller reduces wiring and simplifies installation (No LC-1 required)
• Wideband O2 Sensor is compatible with all fuel types (Leaded, Unleaded, Diesel, Methanol, E85, etc)
• Ability to calibrate O2 sensor for increased accuracy
• (2) 0-5v fully programmable linear analog outputs for use with engine management systems “closed-loop” and external dataloggers
• Interchangeable faceplates and bezels: Black and silver bezel, black and white faceplates included
• Large digital readout and programmable “Digital Needle” provides the functionality of a needle style gauge with the pinpoint accuracy of a digital display
• Datalog using LogWorks on your PC
• Serial IN and OUT ports
MTX-L: Complete All-In-One Air/Fuel Ratio Gauge Kit. Includes: Gauge, Silver Bezel, Black Bezel, White Faceplate, Black Faceplate, Bosch Wideband O2 Sensor (LSU4.2), 8 Ft. Sensor Cable (Overall length 10 ft.), Exhaust Bung, Program Cable (Only needed for Datalogging and to change the Fuel Type Setting), Software CD, and Quick Start Guide. P/N: 3844
Installation of the MTX-L is relatively simple. Complete documentation is supplied, and the support pages, user forum, videos, application notes and tuner resources can also speed you on your way to effective tuning. Innovate also has a great network of local dealers, tuners, race shops, and dyno shops that can assist you in choosing, installing, and getting the most out of your Innovate products.
Old Jan 14, 2011 | 04:45 PM
germanracing's Avatar
I have the same gauge, really love it!
But I couldn't figure out yet how to get it connected to the openport2... It has 1 out cable and 2 wires that can also output the data... Now I'm trying to solder a 2.5mm headphone jack to one of those outputs but since I'm not very technical I haven't got the slightest idea a)how to program the output so it scales correctly b) which of the 3 outputs to solder to the headphone-jack c) how to log that data via openport2, i.e. what address to poll or whatever...
Kind of stumped right now. I'm sure it's easy once you know how, but it seems like nobody on here has done it yet...
Old Jan 27, 2011 | 08:46 AM
bump
Old Feb 2, 2011 | 04:28 PM
ttt
Old Feb 11, 2011 | 09:27 AM
bump
Old Feb 27, 2011 | 12:36 PM
ttt
Old Mar 22, 2011 | 10:33 AM
bump!
Old Mar 31, 2011 | 09:23 AM
bump
Old Apr 6, 2011 | 08:15 AM
Please let us know if you have any questions or to request a quote!
Old Apr 27, 2011 | 09:09 AM
Let us know if you need a quote!
Old May 11, 2011 | 09:21 AM
MRGEVO's Avatar
Hey mate, will this require frequent free-air recalibrations like the LC1? (I find that really annoying with the LC1).
Cheers, Martin.
Old May 11, 2011 | 10:00 AM
Cheers, Martin.
good question Martin, I haven't used one yet to know for sure. We do carry the AEM UEGO which auto calibrates. I've used countless numbers of these without a problem and it would be a great alternative: http://www.mellonracing.com/index.ph...roducts_id=229
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features Include:
Bosch sensor included!
24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda
Integrated three-digit display reveals AFR or Lambda in real time User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
Ideal AFR monitoring tool for carbureted applications and engine dynamometers
Does not oscillate AFR like narrow band sensors
Serial data stream included for output of AFR (RS 232)
Accurate to 0.1 AFR
Old Jun 19, 2011 | 09:00 AM
ttt!
Chris@nolimitmotors
Evo 'For Sale' Electronics / Lighting / Audio
Jan 13, 2017 10:27 AM
Chris@nolimitmotors
EvoX 'For Sale' Electronics / Lighting / Audio
Jan 13, 2017 10:26 AM
Giuna99
Apr 17, 2016 08:35 PM
maperformance
68
Oct 4, 2012 08:31 AM
