BC CAM+VSR<$550 Shipped!>Exedy Stg1-$549, Exedy Stg2-$699, ACT HDSS-$649!!w/Flywheel!
Brian Crower Camshafts Evo8/9 + Brian Crower Valvesprings & Retainers
Stage 2 Duration: 272 In / 272 Ex - Lift: 10.54 in / 9.86 Ex
-Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec.
-OEM spring OK.
Stage 3 Duration: 280 In / 280 Ex - Lift: 10.8 in / 10.36 Ex
-Longer duration profile, added rpm potential. Intended for fully built engine.
-Tuning and ECU mods recommended. Requires spring & retainer kit BC-0100.
ValveSpring Pressure
-Seat: 1.550" @ 95 lbs
-Open: 1.000" @ 235 lbs
-Coil Bind: 0.935"
-no machine work required
Evo8 $550 Shipped! Evo9 $650 Shipped!
HKS Camshafts Evo8 + Brian Crower Valvesprings & Retainers
-HKS camshafts are made from new billets of high nickel content iron alloy
-Duration: 264 In / 264 Ex - Lift: 10.8 in / 10.2 Ex
-Duration: 272 In / 272 Ex - Lift: 10.8 in / 10.2 Ex
-Duration: 280 In / 280 Ex - Lift: 10.8 in / 10.2 Ex
$799 Shipped!
Eagle Connecting Rods H-Beam
-ARP Rod Bolts
-Over 600 HP
$349 Shipped!
Click Here for More Engine Part Specials -- UPDATED DAILY!!
Mix and Match Clutch and Flywheel Pacakges!!
Gruppe-S 10.5 Forged Flywheel
ACT 13.1 lbs Chromoly Streetlite Flywheel
EXEDY STG 1 + Flywheel
-Torque Capacity Increase 44%
-Clamp Load (lb): 2300
-Light pedal feel, crisp engagement
-Holds up to 339 ft-lb wheel torque
-Recommended for Stage 1-2 applications (Stock Turbo + cams)
Combo with:
Gruppe-S Flywheel $549 Shipped!!!
ACT Flywheel $629 Shipped
EXEDY STG 2 + Flywheel
-Torque Capacity Increase: 96%
-Clamp Load (lb): 3010
-Holds up to 385 ft-lb wheel torque
-Recommended for Big Turbo up to GT30R
Combo with:
Gruppe-S Flywheel $699 Shipped!!!
ACT Flywheel $749 Shipped
ACT Heavy Duty Full Face + Flywheel
-38% increase in clamping force over OEM pressure plate
-Torque capacity of up to 497 lb-ft at the flywheel
Combo with:
Gruppe-S Flywheel $649 Shipped!!!
ACT Flywheel $699 Shipped
Exedy Twin Plate
-Recommend for Big Turbo Applications
-430 wheel ft-lb torque capacity
-Includes Flywheel, twin disc, pressure plate
-Light pedal feel, smooth engagement,
-Recommended for BIG POWER CARS GT35R+
-Very Low Price
PM FOR PRICE!!!
Also add a Peak Performance Stainless Steel Clutch Line to any of the above clutch combo! Many competitors offer a similar clutchline, be sure to order one with a sleeve or coating over the steel braid. The Peak Performance line is covered with a beautiful smoke sleeve that will keep the steel braid from harsh environmental conditions.
$30 Free Shipping!!
Click Here for More Drivetrain Part Specials -- UPDATED DAILY!!
-OEM spring OK.
-Coil Bind: 0.935"
$799 Shipped!
-ARP Rod Bolts
-Over 600 HP
$349 Shipped!
Combo with:
Combo with:
Combo with:
Exedy Twin Plate
-Very Low Price
PM FOR PRICE!!!
$30 Free Shipping!!
