AWD Motorsports 2pc Aluminum Driveshafts!! In STOCK!!!
Old Sep 8, 2009, 01:16 PM
  #76
AWD Motorsports's Avatar
ttt
AWD Motorsports is offline
Old Sep 8, 2009, 01:20 PM
  #77
Import Junky's Avatar
I will definately have this on my car within a year. once I feel my setup is maxed out then I'll be focusing more on some weight reduction.
Import Junky is offline
Old Sep 9, 2009, 12:23 PM
  #78
2 available tomorrow..
Mike
Old Sep 9, 2009, 09:10 PM
  #79
Huy's Evo's Avatar
do u have a pic of it under the car installed? and is that the rear propeller shaft and does it delete both center bearings and connect to the front propeller shaft?
Huy's Evo is offline
Old Sep 9, 2009, 09:25 PM
  #80
I dont have a pic on hand of the full installed setup.. I should have one though.. just dont know where.. That is the rear you see and front connects direct to it.. it does not delete the center bearing.. that assembly bolts up to the stock location..
Mike
Old Sep 9, 2009, 09:31 PM
  #81
EmeryatSTM's Avatar
Mike
Mike, As soon as I install mine I will get you some good pics. These things are awesome!
The last one we installed we did back to back test with and without it and picked up 10+ HP all the way through on our Mustang dyno! And that was only with a stock turbo. I can only expect bigger gains and better spool times on bigger turbo...
-Em
EmeryatSTM is offline
Old Sep 10, 2009, 10:13 AM
  #82
2 coming in today./.
Old Sep 12, 2009, 09:36 AM
  #83
Weekend Bump!!! 2 In stock!!!
Old Sep 14, 2009, 12:52 PM
  #84
ttt
Old Sep 16, 2009, 12:34 PM
  #85
2 more units arriving tomorrow..
Old Sep 21, 2009, 04:00 PM
  #86
ttt
Old Sep 22, 2009, 03:33 PM
  #87
2 in stock..
Old Sep 23, 2009, 11:13 AM
  #88
In stock!!!
Old Sep 24, 2009, 11:13 PM
  #89
Huy's Evo's Avatar
any pics yet? i looked at the driveshaft and it doesnt look the rear propeller shaft has joint where u can bolt it up like the pic u have. it has a cv joint then the #4 joint that goin to the pinion. i know u guys are busy but before i like to buy something i like to see it on the car
Old Sep 24, 2009, 11:20 PM
  #90
AF-Evo8's Avatar
hey mike do you have suggestions as to the best carrier to use to ship the core to you? i was under my car today and i was trying to figure out how the hell you would box this thing properly.
AF-Evo8 is offline
Quick Reply: AWD Motorsports 2pc Aluminum Driveshafts!! In STOCK!!!
