ARP | Brian Crower | Exedy | ACT | Kelford | Manley | more
GSC Cams Available
GSC Power Division Cams now available
Evo 4-8
S1
The GSC Power-Division S1 cams for the Mitsu Evolution 4-8 are designed for those with the stock turbo up to the GT30/50Trim. These cams will not sacrifice any bottom end loss over stock cams; nothing but gains and will promote faster spooling of the upgraded turbos. Gains of 30-55whp (depending on Turbo) have been seen by simply bolting the S1 cams in. Designed for a rev range of 3000-8000rpms, these cams work well on the stock valve springs. 300-450whp camshaft. Idle is slightly rougher than stock.
S2
The S2 cams are designed for those with a GT35R-GT4067 Turbo. No low end power is lost vs the stock cams when used with the larger turbo. The S2 cams will show gains of 50-70whp over the stock cams and in some cases more in the higher RPMS. Great for 2.0L engines revving to 9000rpms or for Stroker motors revving to 8000rpms. The S2 Cams require upgraded valve springs (check out GSC’s Chro-Molly Retainers and single valve spring kit for a perfect upgrade to your valve train). Designed for a rev range of 4000-9000 RPMS(2.0L or 3000-8000 2.2L+), 500-700whp applications. Not suggested for smaller stock appearing turbo setups. S2 cams can run on Factory ECU with custom flashing.
S3
The S3 Cams are avalible in a Solid Lifter cam and a Hydraulic Lifter Cam for the Evo 4-8 4G63. These cams are ment for the 800whp+ to take advantage of a very large turbo. these are NOT suggested for anyone running smaller than the 67mm to GT42R turbo.
Evo9
S1
GSC Power-Division's Evo 9 S1 cams are designed for those with a stock turbo all the way to a GT30/50Trim. These cams will not sacrifice any bottom end loss over stock cams; nothing but gains and will promote faster spooling of the upgraded turbos. Gains of 25-40whp (depending on Turbo) have been seen by simply bolting the S1 cams in. Designed for a rev range of 3000-8000rpms, these cams work well on the stock valve springs. 300-450whp camshaft.
S2
GSC Power-Division Mivec S2 cams are designed for those with a GT35-GT37 Turbo. No low end power is lost vs the stock cams when used with the larger turbo. The S2 cams will show gains of 40-50whp over the stock cams and in some cases more in the higher RPMS. Great for 2.0L engines revving to 9000rpms or for Stroker motors revving to 8000rpms. The S2 Cams require upgraded valve springs (check out GSC’s Chro-Molly Retainers and single valve spring kit for a perfect upgrade to your valve train). Designed for a rev range of 4000-9000 RPMS(2.0L or 3000-8000 2.2L+), 500-700whp applications. Not suggested for smaller stock appearing turbo setups. S2 cams can run on Factory ECU with custom flashing.
S3
The S3 Cams are avalible in a Solid Lifter cam and a Hydraulic Lifter Cam for the Evo 4-8 4G63. These cams are ment for the 1000whp+ to take advantage of a very large turbo. these are NOT suggested for anyone running smaller than the GT42R and should not even be considered!
Evo 4-8
S1
S2
S3
Evo9
S1
S2
S3
