Competition, Exedy, Quartermaster, ACT, Spec, JE, Manley, Kelford--LOW Pricing!!!
Is your Clutch slipping, are you tired of the stock cams or are you just looking to go all out and build your motor? Well DG Motors has you cover on all aspects for your evo!!!!!
If there is anything else you are interested in that is not listed feel free to ask as we are a full time parts supplier and can get just about anything for your Evo/ Dsm. Remember we are here to serve you the best and we will do our best to compete with the rest and try to get you the lowest prices possible for you car.
![](http://img197.imageshack.us/img197/640/specclutch.jpg)
Call or PM for Special Pricing!!!!
JE Pistons has the most dedicated, passionate personnel designing and manufacturing parts that are BATTLE TESTED, and considered BEST IN CLASS by today's most demanding sport compact professionals. Whether you're into ROAD RACING, DRIFTING, DRAG RACING, or just finding a piston that can withstand the most EXTREME demands, JE can help. JE has experience developing custom pistons for every sport compact make and model imaginable, the most complete lineup with hundreds of parts on the shelf ready to ship, over 40 new shelf parts recently designed, and more under continual development.
The 1400HD line of pistons has been developed for extremely high horsepower applications. They utilize a 2618 alloy which is the strongest available on the market today and include .225" tool steel wristpins and heavy duty rings to complete the ultimate 4g63 piston!
$1279.99 Shipped to your door!!!!
![](http://img255.imageshack.us/img255/2741/compclutch.jpg)
Competition Clutch's new twin disk for the Evo platform has finally arrived. It is the perfect choice for enthusiasts searching for a cost effective twin disk clutch kit that will hold upwards of 700whp! Utilizing the ideal flywheel weight and a linkage type pull to push conversion also provides improved driveability over the competition! ![](http://img255.imageshack.us/img255/2741/compclutch.jpg)
Call or PM for Special Pricing!!!!!
![](http://img291.imageshack.us/img291/9809/dtevoquartermaster.jpg)
This clutch also allows for faster shifting based on the reduced rotating weight and smaller diameter discs. You will be able to shift faster than you ever imagined was possible with your old single disc! The only downside to this beast is the engagement as it can be quite harsh until you get used to it!
Call or PM for Special Pricing!!!!!!![](http://img14.imageshack.us/img14/7015/exedy.jpg)
For high-powered applications EXEDY offers multi-plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi-plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance.![](http://img291.imageshack.us/img291/9809/dtevoquartermaster.jpg)
![](http://img132.imageshack.us/img132/12/actbig.jpg)
A popular choice for your mildly modified street driven Evo!
![](http://img188.imageshack.us/img188/5104/jepiston.jpg)
![](http://img30.imageshack.us/img30/2356/wisecohd01.jpg)
![](http://img136.imageshack.us/img136/6758/maleyibeam.jpg)
Manley Pro Series connecting rods are forged from aircraft quality 4340 vacuum degassed material. Each rod is fully machined in the Manley Lakewood, NJ factory to the highest standards. Our signature "Turbo Tuff" design combines the appropriate weight and rugged strength for ultimate horsepower applications. Each rod is shot peened after machining and magnafluxed. Bores are round and without taper. Bend and twist is tightly controlled. Cap fasteners are 3/8" APR 2000 cap screws.![](http://img136.imageshack.us/img136/6758/maleyibeam.jpg)
![](http://img44.imageshack.us/img44/1984/kelford.gif)
This range of hydraulic lifter cams is dyno and race track proven. Kelford Cams range of high quality camshafts for Mitsubishi EVO 8 are ground on a masterless Toyoda CNC camshaft grinder.
