Mellon Tuning - BR Stage 3 Cylinder Head /ForcedPerformance*GSC*Kelford*Camshafts
Buschur Racing Stage 3 Cylinder Head
Standard assembly includes:
- Custom BR dual stainless steel valve springs
- BR titanium retainers
- New Valve Seals
- BR stainless .5mm over intake valves
- BR stainless .5mm over exhaust valves
- Stainless Oring around each combustion chamber
- Complete port & polish job
- Stainless Steel O-Ring
* New Bronze Valve Guides are additional
* Add Inconel Exhaust Valves instead of S.S.
* New Valve Seats
Instead of throwing around flow bench numbers that can't be compared to other flow benches anyway, we're going to list our percentage gains at 5 valve lift positions vs our stock baseline flow numbers:
Lift at the valve / Intake % / Exhaust %.
100" / +27% I / +10% E
200" / +19% I / +10% E
300" / +14% I / +19% E
400" / +19% I / +23% E
500" / +20% I / +29% E
All ports were flowed on their own at 28inches, without intake or exhaust tubing. It is important to not just look at someone's advertised flow ratings,
because CFM ratings don't mean anything unless they are from the same head,
on the same bench, with the same operator, under the same conditions.
That is why we are showing you the improvements we have made rather than just quoting you some b.s. number in an attempt to win your business.
NO GIMMICKS HERE! This is the SAME head that is used on the Mellon Tuning Evo , and also was used on the 8sec black drag Evo as well as David's personal street driven Evo that went 9.0 and EVERY high hp fast Evo .
NOTE: This service requires good core, core charge additional if you cannot supply one.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=152
Buschur Racing BF272 Evo 8 Camshafts
Just released.... The ultimate in EVO camshafts. This new custom grind from Buschur Racing has proven itself to make the most power of any camshaft we have tested to date in the EVO.
We've had these cams custom ground and are glad we can offer them at a reasonable price to our customers.
These camshafts are recommend for GT30 series turbos or larger and will require a spring and retainer kit to support them. (sold seperately)
PLEASE NOTE: We really do not recommend to use these cams with the stock shortblock for your added safety.
Its possible that the valves could hit the pistons. It all depends on your valve spring combination and RPM.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=135
Evo 8 Forced Perfomance Camshafts
Forced Performance 4R Evo 8 Cams
Designed around factory valvetrain and piston clearance limitations.
Increase in mid and upper RPM power.
Can be used with factory valve springs and retainers to 8K rev limit,
but FP beehive
spring kit recommended.
Can be used with factory pistons.
Somewhat lumpy idle.
Recommend increasing idle RPM to ~1000RPM.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=455
Forced Performance 5R Evo 8 Cams
Spring upgrade required, will not work with factory retainers.
Must check for coil bind.
11K RPM capable with good springs.
Further increase in upper RPM power.
Intended for use with 65+ lb/min turbos.
Works well with header equipped engines.
Not intended for use with factory pistons.
While most aftermarket pistons allow for adequate piston to valve
clearance, checking
clearance is highly recommended, especially with oversize valves.
Choppy idle. Recommend increasing idle RPM to ~1200RPM.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=456
Evo 9 Forced Performance Camshafts
Forced Performance 4R Evo 9 Cams
The FP4R camshafts are ground on only the highest quality blanks with generous radius for the oil grooves for max strength and durability.
There have been ZERO failures of the FP4R EVO9 MIVEC camshaft. To date, 4/27/10, ZERO FP EVO9 camshafts have broken.
The FP4R grinds for the EVO9 are designed around the factory valvetrain and piston clearance limitations and have .440" lift.
This means that this grind is completely compatible with the stock engine with stock retainers, guides, seals, valves etc and can be dropped into an otherwise stock engine with great results.
The grind can be safely operated beyond the stock redline to 8krpm with the stock springs in place, and operated to 9krpm with the recommended FP Beehive springs.
This grind gives good clearance with the factory EVO9 pistons at all locations of MIVEC advance or retard.
There is a slight decrease in idle vacuum, and a slight increase in idle RPM may be required but good idle below 1000rpm is typical.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=454
Forced Performance 5R Evo 9 Cams
The FP5R camshaft grinds require a spring upgrade, it is not possible to use the factory retainers or springs due to the increase in the lift to .475" with this grind.
Installer must check for coil-bind and retainer/seal contact during assembly. While most aftermarket pistons allow for adequate piston to valve clearance, checking this clearance is highly recommended in ever case, this need is even greater when using oversize valves.
Like the 4R grind, the larger 5R grind is very well suited to high RPM operation and is capable of 11krpm with the proper spring setup. The FP5R gives a further increase in upper RPM power over the 4R grind and turbo selection should reflect this extra upper RPM capacity.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=137
GSC Evo 8 Camshafts
GSC S1 Evo 8 Camshafts
The S1 cams are designed for those with the stock turbo up to the GT30, 50Trim/Green, Red, Black, BBK.
These cams will not sacrifice any bottom end loss over stock cams; nothing but gains and will promote faster spooling of the upgraded turbos.
Gains of 30-55whp (depending on Turbo) have been seen by simply bolting the S1 cams in. Designed for a rev range of 3000-8000rpms, these cams work well on the stock valve springs. 300-450whp camshaft.
Idle is slightly rougher than stock. S1 Specs (part # gsc-6008S1) Intake 268 Duration 10.50mm peak lift, 107 degree Centerline Exhaust 266 Duration 10.50mm Peak Lift, 113 degree Centerline.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=297
GSC S2 Evo 8 Camshafts
The S2 cams are designed for those with a GT35R-GT4067 Turbo. No low end power is lost vs the stock cams when used with the larger turbo.
The S2 cams will show gains of 50-70whp over the stock cams and in some cases more in the higher RPMS. Great for 2.0L engines revving to 9000rpms or for Stroker motors revving to 8000rpms.
The S2 Cams require upgraded valve springs (check out GSC's Chro-Molly Retainers and single valve spring kit for a perfect upgrade to your valve train). Designed for a rev range of 4000-9000 RPMS(2.0L or 3000-8000 2.2L+), 500-700whp applications.
GSC doesn't suggest running these on smaller stock appearing turbo setups but we've seen gains over the S1 with these. S2 cams can run on Factory ECU with custom flashing.
S2 Specs (part # gsc-6008S2)
Intake 274 Duration 11.2mm peak lift, 107 degree Centerline
Exhaust 272 Duration 11mm Peak Lift, 113 degree Centerline
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=299
GSC S3 Evo 8 Camshafts
The S3 Cams are a Hydraulic Lifter Cam for the Evo 4-8 4G63. These cams are designed for 700whp+ to take advantage of a very large turbo with a lot of flow capability!
S3 Specs:
6008S3 ADV Duration Duration @ 1mm Peak Lift CenterLine
Intake 280 238 11.50mm 108
Exhaust 280 238 11.50mm 116
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=444
GSC Evo 9 Camshafts
GSC S1 Evo 9 Camshafts
Gains of 25-40whp (depending on Turbo) have been seen by simply bolting the S1 cams in. Designed for a rev range of 3000-8000rpms, these cams work well on the stock valve springs. 300-450whp camshaft.
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=298
GSC S2 Evo 9 Camshafts
The S2 cams are designed for those with a GT30-GT37 Turbo. No low end power is lost vs the stock cams when used with the larger turbo.
The S2 cams will show gains of 40-50whp over the stock cams and in some cases more in the higher RPMS. Great for 2.0L engines revving to 9000rpms or for Stroker motors revving to 8000rpms.
GSC doesn't suggest the S2 for smaller stock appearing turbo setups, but we've seen gains over the S1. S2 cams can run on Factory ECU with custom flashing.
S2 Specs gsc-6009S2
Intake 274 Duration 11.2mm peak lift, Variable Centerline
Exhaust 272 Duration 11mm Peak Lift, 115 degree Centerline
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=300
GSC S3 Evo 9 Camshafts
The S3 Cams are a Hydraulic Lifter Cam for the Evo 9 4G63.
These cams are for the 700whp+ to take advantage of a very large turbo.
S3 Specs:
6009S3 ADV Duration Duration @ 1mm Peak Lift CenterLine
Intake 280 238 11.70mm 130
Exhaust 280 238 11.70mm 115
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=445
Kelford Evo 8 Camshafts
Kelford 272 Cams EVO 8
Kelford Cams range of high quality camshafts for Mitsubishi EVO 8
TX272 The Best 272 degree cam on the market, suits 300+ HP engines
Approx RPM Range:
Duration @ 0.1mm Valve Lift: 272 Inlet/272 Exhaust
Duration @ 1.0mm Valve Lift: 226 Inlet/226 Exhaust
Valve Lift @ 1.73 Rocker Ratio: 11.00mm Inlet/11.00mm Exhaust
Centerline @ Full Lift: 107 Inlet/113 Exhaust
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=348
Kelford 280 Cams EVO 8
Drag racing camshafts, high end HP, suits nitrous and high boost.
Approx RPM Range:
Duration @ 0.1mm Valve Lift: 280 Inlet/280 Exhaust
Duration @ 1.0mm Valve Lift: 238 Inlet/238 Exhaust
Valve Lift @ 1.73 Rocker Ratio: 11.50mm Inlet/11.50mm Exhaust
Centerline @ Full Lift: 107 Inlet/117 Exhaust
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=350
Kelford 280/272 Cams EVO 8
Suits large turbo street / strip applications
Approx RPM Range:
Duration @ 0.1mm Valve Lift: 280 Inlet/272 Exhaust
Duration @ 1.0mm Valve Lift: 238 Inlet/226 Exhaust
Valve Lift @ 1.73 Rocker Ratio: 11.50mm Inlet/11.00mm Exhaust
Centerline @ Full Lift: 105 Inlet/115 Exhaust
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=352
Kelford Evo 9 Camshafts
Kelford 272 Cams EVO 9 Mivec
Kelford Cams world leaders in high performance Mitsubishi camshafts, now available for the EVO 9 MIVEC.
272 degree cams for racing applications, stock or larger turbo, suits nitrous
Approx RPM Range:
Centerline @ Full Lift: 130 Inlet/113 Exhaust
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=349
Kelford 280 Cams EVO 9 Mivec
Drag racing camshafts for EVO9, top end performance for serious engine builds
Approx RPM Range:
Duration @ 0.1mm Valve Lift: 280 Inlet/282 Exhaust
Centerline @ Full Lift: 130 Inlet/115 Exhaust
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=351
Kelford 280/272 Cams EVO 9 Mivec
280/272 degree high performance EVO9 camshaft set, suits large turbo street / strip car
Approx RPM Range:
Centerline @ Full Lift: 128 Inlet/115 Exhaust
www.mellontuning.com/index.php?main_page=product_info&cPath=1_16_20&pro ducts_id=353
If u have any quiestions or if you need help selecting the perfect camshaft for your set-up , u can pm me or u can email me at Gary@MellonTuning.com
Mellon Racing
EvoX 'For Sale' External Engine / Power
396
Nov 28, 2014 06:42 AM
Mellon Racing
56
Jul 11, 2011 07:11 AM
Mellon Racing
72
Jun 27, 2011 07:02 AM
Mellon Racing
Feb 28, 2011 01:42 PM
Mellon Racing
Feb 23, 2011 07:38 AM
