Clutch and Flywheel Deals Inside - ACT / Clutchmasters / Comp Clutch / Exedy / SPEC
Here at JB Autosports we know how important it is to have your car back on the road along with that awesome feel only an AWD launch can provide. It's pretty hard to get that sub 1.6 60ft time, or perfect autocross start with a slipping clutch. With winter coming or having arrived already for some of you it's a great time to replace that failing or about to fail clutch.PM us for the special EvoM Forums price.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Like us on Facebook for Facebook only specials!
Clutchmasters
The entire line of ClutchMasters is available. The FX100 to the FX500 and even their extremely affordable Twin Disc!
Clutch Masters
Clutchmasters Flywheel
Clutch Masters Aluminum Flywheel - 12LBS
Exedy
For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Exedy Single, Twin, or even Triple available.
Comp Clutch
Competition Clutch brings to their customers the finest materials, workmanship, and the best customer service in the industry. We offer higher clamping force, stronger disc designs, and uncompromised satisfaction, all at the most competitive pricing in the industry. Stage 1 through Stage 5 available. We run their Stage 4 in our Sponsored Evo 9 MR.
Comp Clutch Kits
Comp Clutch Flywheel - 11LBS
SPEC Clutch
SPEC Clutches and Flywheels are manufactured on-site using the most advanced methods under the strictest tolerances. We wouldn’t have it any other way. Our commitment to making the very finest parts is at the core of what we stand for as a company. Don’t accept anything less. Stage 1 all the way up to their Twin Disc.
SPEC Clutch Kits Stage 1, 2, 3, 3+, 4 or TWIN Disc!
SPEC Flywheel
Fidanza
Fidanza Aluminum Flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight.
Fidanza Flywheel
Clutchmasters
Clutch Masters
Exedy
Comp Clutch
Comp Clutch Kits
SPEC Clutch
SPEC Flywheel
Fidanza
Fidanza Flywheel
