Built Short Blocks Cyliner Heads Performance Race Solutions Built in House
Built Short Blocks Cylinder Heads Performance Race Solutions Built in House
You may ask who are we? We have been in business for 3 years under our name and have been growing each year significantly. We have a state of the art machine shop with a machinist with over 30 years experience. His experience consisted of 100s of evo/ dsm engine builds and really shines in his cylinder heads. We also offer full in-house tuning and installation services for those of you local to us or would be interested in shipping your cars to us for a build.
Email or call us today with any questions or to place an order
Mitsubishi Evo 8 & 9 built short & long blocks (2.0, 2.1, 2.3, 2.4)
PRS Stage 1 2.0L & 2.4L Short Block 400+WHP
Wiseco or Manley Pistons
Manley H-Beam Rods
ACL Race Series Rod & Main Bearings
All freshly bored and honed to each specific piston with a torque plate
Freshly Resurfaced
Build sheet Specs
Available options include: balanced assembly, Custom piston and long rod options
Price - $2400 + Core
Add $700 for a 2.4L core, Pm for availability on 2.0 cores and pricing unless you want to send yours in for a rebuild.
PRS Stage 2 2.0L & 2.4L Short Block 700+ WHP
Wiseco HD or Manley Pistons
Manley Turbo Tuff I-Beam Rods
APR Main Studs
Freshly Resurfaced
Build sheet Specs
The 2.4L utilize a 100mm crankshaft, larger bore, and 6mm taller deck to increase displacement. The 2.4 is also offered in a long rod option which improves upon the rod ratio allowing higher reving. 2.4L Core charges are significantly cheaper than the 2.0L core.
Price - $2950 + Core
PRS can build blocks to hold any of your HP goals, We have 2.4 blocks instock just waiting on piston and rod choice. They can be shipped out in a little as one week or installed here at our location in Orlando, FL
PRS Cylinder heads
Stage 1
Includes:
•Clean / Hot Tank
•Visual Evaluation / Inspection
•Deck Resurface to High Performance RA Specs
•Performance Valve Job (Performed with Serdi 3.0 which provides the finest valve jobs in the industry)
•New Valve seals
•Assembly & Vacuum tested
$500 If you do not have a core pm us for a price on one!
Additional Options:
Guide replacement $180
Super Tech black nitrated valves OE $225
Ferrea 6000 valves OE $235
Valve Seat replacement $60 each
Beehive Springs OE retainers $200
Stage 2
•Clean / Hot Tank
•New Valve Seals
•Porting of bowls
$850 If you do not have a core pm us for a price on one!
Additional Options:
Super Tech black nitrated valves OE or +1mm $225
Ferrea 6000 valves OE or +1mm $235
Beehive Springs Oe retainers $190
Supertech Dual valve springs $389
Custom porting available oversized intake and exhaust runners, combustion chamber
Stage 3 Race
Included from our stage 2 build plus
•Race Port/ Polish includes mild castings on intake and exhaust runners, bowl porting (not your average sandpaper porting!)
•Supertech black nitrided valves
•GSC Beehive Springs/ stock retainers (good for 9000RPMS) minus $200 if springs are not needed
$1850
Custom options include Valve & spring choices add $180 for guide replacement
Stage 4 Race (our head picked up 80+whp on our race car) For those of you looking to make 800+
Included from our stage 3 build plus
•Extreme Race Port/Poilish enlarged intake and exhaust runners, bowl porting
•Supertech +1mm Black Nitrated/Inconel
•GSC Beehive Springs with titanium retainer & 4340 Chro-molly Seat (good for 11000RPMS)
$2100
Place your order today for black Friday- through Monday 11-26 and recieve free rotating assembly balancing $275 value
Quite a few Evos in for Services Dont forget to inquire today for any of your Evo's needs
Shaun@AWDMotorsports
Evo 'For Sale' Engine Internals and Drivetrain
206
Feb 6, 2016 05:36 PM
PRS
35
Dec 19, 2013 10:24 AM
PRS
85
Aug 15, 2012 03:33 PM
PRS
EvoX 'For Sale' Suspension / Brakes / Handling
38
May 30, 2012 03:44 PM
