Perrin............
Perrin............
Perrin Catbacks, Perrin Cat Delete Pipes, Perrin Downpipes!!!!!!!!!
IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!IN STOCK!!!
Perrin Catback Exhaust
Full 3 Inch System
High polish tubing
Fully Flanged System
Single 4 Inch Slash Cut Tip
The PERRIN Evolution Exhaust is constructed of full 3" prepolished stainless steel. Fully flanged complete cat-back unit, which does not affect emissions related hardware. Every PERRIN exhaust application bolts-on using factory-mounting hangers. The straight-though exhaust design allows for peak performance and horsepower.A 4", slash cut, stainless steel tip sets this system apart. Mandrel bent, prepolished, stainless steel tubing, thick laser-cut flanges, factory style hangers, and a polished stainless-steel muffler and tip.
$614.99 plus shipping
The Perrin cat delete pipe is used to replace your stock catalytic converter for added performance. Simple bolt on performance easily pumps up the horsepower out put of your Evo in seconds. Constructed of all stainless steel materials. 3” 304 stainless steel tubing. 1/2 inch stainless steel flanges.
The Perrin Cat delete pipe has a strait through design and is a full 3 inches in diameter. Any smaller and you pinch off the exhaust gases. Larger and you create a pressure drop.
The Perrin cat-delete pipe is produced exclusively from 304 stainless steel. The 3 inch center section has no bends for a strait through, high flow design. Stout 1/2 inch flanges are used to prevent any warping from high temperatures. (Unusually high temperatures can occur from use of a larger turbo or under racing conditions.) Finally the entire piece is polished to a mirror finish.
The Perrin Performance cat delete pipe is the first to come with an O2 simulator. The Perrin Performance O2 Simulator attaches into the vehicles wire harness simulating the natural operations of an Oxygen sensor. Your computer will not know that you have removed the vehicles catalytic converter.
$164.99 plus shipping
Perrin Downpipe
The brand new Perrin downpipe for your Mitsubishi EVO VIII is now available. 3 inch stainless steel with 1/2 inch thick flanges. The turbo flange uses a donut gasket fit for best fitment. Includes factory hanger mounts and can be used with the stock cross bar or aftermarket ones. Downpipes are designed to give the car about 10 HP in the higher RPM while keeping the turbo spooled through the gears.
$284.99 plus shipping
also available Perrin Turboback System
Vivid Racing is proud to release the Perrin Turboback Exhaust by Vivid Racing. Vivid has taken Perrin's 3 major exhaust components for the Mitsubishi EVO VIII and packaged them into one!
You get the Perrin Performance 3 inch downpipe, the 3 inch cat delete pipe, and the 3 inch catback system giving you a full stainless steel 3 inch turboback system.
What is best about the Perrin system is that the cat delete pipe includes a CEL eliminator...NO MORE CHECK ENGINE LIGHT! The exhaust is a single 4 inch tip straight through design for a great sound. The pipes are all mirror polished, except the downpipe. This setup should gain you about 20+ wheel horsepower on your EVO VIII.
$909.99 plus shiping
Questions? Orders? Pm or call me at 1.866.44.vivid ext 226
jacky
Full 3 Inch System
High polish tubing
Perrin Downpipe
jacky
Link no worky .
[edit] The link for the sound file, that is. Even if you edit out the extra http// in there it still doesn't work. http://www.vividracing.com/main/PerrinEVOVIII.wmv
Originally Posted by UFO
Link no worky .
Vivid Racing
Mar 4, 2005 07:08 PM
Vivid Racing
Dec 30, 2004 02:14 PM
Vivid Racing
17
Oct 25, 2004 06:38 PM
