Fidanza Cam Gears
Old Oct 30, 2004 | 11:09 AM
GregGSC's Avatar
Fidanza Cam Gears
Fidanza adjustable cam gears are made from the highest quality 6061 T6 aluminum. They are CNC machined to more exacting tolerances than original gears.The tooth edges are beveled to increase belt life. With twelve degrees (both advance and retard) of laser etched adjustments you can be assured of proper tuning.
The inner ring is designed for strength, function, and precision. Stainless steel studs are threaded through the backside of the outer gear. The inner gear is then fastened with stainless steel nuts and lockwashers. This enables an increase in the amount of torque used to tighten the fasteners, with no risk of stretching to the aluminum threads.
We have silver red and blue in stock and the price is $215 Shipped for the pair!
Old Oct 30, 2004 | 08:38 PM
144mph's Avatar
everyone, FYI, the fidanza catalog lists the same part numbers for evo's as 90-99 dsm's. Pretty sweet considering some other guy is offering them for 240 a set on www.dsmtuners.com.
Old Nov 15, 2004 | 09:58 AM
GregGSC's Avatar
just got some more in stock and also have one set of HKS gears here.
Old Nov 15, 2004 | 10:58 AM
zstryder's Avatar
$185, that's dirt cheap. bump for you!
Old Nov 15, 2004 | 10:59 AM
en1gma19's Avatar
pm sent
Old Nov 15, 2004 | 08:06 PM
GregGSC's Avatar
Pmed back to you and thanks for the order!
Old Nov 15, 2004 | 08:09 PM
en1gma19's Avatar
no prob can't wait to recieve them.
Old Nov 17, 2004 | 10:33 AM
EVOtagger's Avatar
i'll take a pair (red)...ill try to get the order in tonight after work
Old Nov 19, 2004 | 01:58 PM
GregGSC's Avatar
one set of Blues here and more silver on the way.
$215 Shipped
