Boomba Racing Fuel Rail and Pulley Set
Boomba Racing is proud to present fuel rail and pulleys set for EVO VIII.
Boomba Racing standard fuel rail is direct replacement of factory unit (mounts directly with factory hardware). Large internal bore allows more fuel flow and can support aftermarket high flow fuel injectors. Rail can supply enough fuel for engines with turbo swaps up to 600 HP. Rail has available extra 1/8 NPT port for installing pressure gage. Parts are CNC machined from aircraft quality billet aluminum. Rails are available in natural aluminum, black anodized, blue anodized or red anodized finishes.
Boomba Racing performance fuel rail can be installed in place of factory unit. Rail has extra large internal bore and both ends have 3/8 NPT threaded ports. Rail requires aftermarket fuel regulator and fuel fittings. This is option for people that have real power in mind. Fuel flow is so great that HP is almost unlimited. Rail has available extra 1/8 NPT port for installing pressure gage. Parts are CNC machined from aircraft quality billet aluminum. Rails are available in natural aluminum or red anodized finishes.
Boomba Racing pulley set is direct replacement of factory pulleys. Pulleys are CNC machined from aircraft quality billet aluminum. They drastically reduce rotating mass at the end of crankshaft and powered by the crankshaft. Because of mass reduction engine response is much quicker. Boomba pulleys are not undedriven which means that amount of power transferred to all engine accessories is the same like with factory pulleys. This eliminates problems with battery charging and num power steering. Parts are available in natural aluminum, black anodized, blue anodized or red anodized finishes.
All parts are in stock and available for immediate shipping. For more information and pricing visit our website www.boombaracing.com.
Boomba Racing standard fuel rail - available in natural, red, blue and black
Boomba Racing performance fuel rail - available in natural and red
Boomba Racing pulley set - available in natural, red, blue and black
