Water/Meth Injection kits 400hp $399
The Delux Single Stage kit offers you a great product at a great price.This kit has the RIGHT size nozzle FOR your car TO ward OFF detonation at boost levels.
Our Deluxe Single Stage Water Injection kit has the following features :
Methanol Safe
90 Day Warranty
150 psi water pump
1 Electronic Solenoids WITH Brass Barb Fittings
15 feet OF high psi water hose
Hose Clamps
Zip Ties
1 adjustable boost pressure sensors
1 water injector nozzle w/anti clog detection
1 custom machined injector holders
1 fuse holder
relay Wiring Harness
30 AMP Relay
16 Gauge Wire
High END Arm / Disarm Rocker Switch(OEM STYLE)
Electrical Connectors
ON call live technical support
large capacity reservoir
injector clog sensor
Setup for cars wanting 400whp on pump gas. This kit uses a boost activated swtich that is adjustable. Also has a premium pump.
Click to Order $399
Originally Posted by go_evo_go
how long beofre refill on these dailydriving and a little boost on the side?
Chris
Originally Posted by anjapower
how much whp gains be realized from straight water injection...no alcohol and no methanol?
27 to 57hp gain depending on mods from what precision dyno tuning tested on 4 different evos.
Chris
Originally Posted by LogicPerformanc
You want the water/alch. to atomize well before it gets to the throttle body, so the upper IC pipe down by the end-tank is a good spot.
Click to Order $399
Click to Order $399
In other words, would you recommend this early in the upgrade path?
Originally Posted by MRinChrist
Would gains be evident without EM?, on an otherwise slightly modified car?
Yes it is a great upgrade because it will work with all other mods better.
Chris
