Exedy Organic Clutch fidanza or Prostreet Online Flywheel and SS Clutch Line Kit
Old Sep 28, 2005, 10:16 AM
GregGSC's Avatar
With all the uproar of the ACT Street Disc clutch kit. GSC has put together a clutch flywheel and clutch line kit that is sure to make a splash. We offer two different flywheel options, one is the Fidanza light weight flywheel for the Evo which is 9.5lbs and has the option of changing the wear surface so that you can keep the same flywheel for different clutches down the road. The other flywheel option is the Prostreet Flywheel which is a one piece design and weighs in at 10.5 pounds. The Fidanza flywheel is lighter than the prostreet which makes it a great choice for the Evo as it will help with lock out of gears when drag racing. The lighter the better in this case.
The clutch we chose to use is the Exedy organic single plate sprung hub clutch kit, which comes with the throw out bearing and an alignment tool. This clutch has a TQ capacity of 450+ foot pounds and the clamping load is 3010 pounds. It is a 44% increase over the stock clutch making it a little heavier on the pedal but still very easy to daily drive. The Exedy Pressure Plate, Street Sprung hub disc and throw out bearing weigh in at 16.5 lbs
We include our GSC Power Division Stainless Steel Clutch line kit. When you install the clutch line kit you will need to remove the restrictor in line, it will make the Evo clutch last longer and have a much more precise pedal feel. With the clutch line kit there will be no more of the pesky first gear slipping. This is mainly do to removing the restrictor but the engagement is crisp and will allow you to slip the clutch yourself for launches and taking off from stoplights. This is a must have for any Evo including cars still on the stock clutch setup.
We are offering free shipping on this deal in the lower 48 states and will provide a $20 discount to Hawaii and over seas customers.
With ProStreet Flywheel $727.10 Shipped!!!!
With Fidanza Flywheel $867.12 Shipped
Link to Buy----> http://www.stikiller.com/catalog/Exe...l-p-16681.html
GregGSC is offline
Old Sep 29, 2005, 04:28 PM
GregGSC's Avatar
btt
GregGSC is offline
Old Oct 7, 2005, 12:19 PM
hel_if_ino's Avatar
btt, I had this kit put on and it is awesome.
hel_if_ino is offline
Old Oct 10, 2005, 08:22 AM
MattGold's Avatar
I had this exact setup holding 390WHP on a Mustang Dyno...
120MPH trap if that tells you anything about this clutch.
MattGold is offline
Old Oct 12, 2005, 04:01 PM
SilverDiamonds's Avatar
How long will this price be around?
SilverDiamonds is offline
Old Oct 13, 2005, 02:13 PM
ProStreetOnline's Avatar
Great clutch, and great flywheel
ProStreetOnline is offline
Old Oct 13, 2005, 03:13 PM
PurgeIt's Avatar
Fidanza makes some good stuff. Their flywheels are top notch.
PurgeIt is offline
Old Oct 21, 2005, 10:22 AM
GregGSC's Avatar
this deal will be here till the end of the month.
GregGSC is offline
Old Oct 21, 2005, 10:29 AM
vone750's Avatar
bump....
vone750 is offline
Old Oct 25, 2005, 10:59 AM
GregGSC's Avatar
Fidanza is out of Ring Gears so we can only offer the clutch with the Prostreet Flywheel right now.
GregGSC is offline
Old Oct 27, 2005, 11:52 AM
rExTuHfEr's Avatar
how long will the fidanza be out?
rExTuHfEr is offline
Old Oct 28, 2005, 08:07 PM
Mike@Forge's Avatar
Greg,
I'm going to finally get in touch with you Monday about the cams, the battery kit, and this clutch kit too, after a little accident at the track tonight with the stock clutch!
Mike@Forge is offline
Old Oct 31, 2005, 10:36 AM
GregGSC's Avatar
Originally Posted by Mike@Forge
Greg,
damn you too I broke my Drive shaft last night and Leh Broke his Diff. Sounds like the weekend was expensive for all of use. give me a shout and well see what we can do.
GregGSC is offline
Old Nov 6, 2005, 03:17 AM
aps
aps's Avatar
How is this combo daily drive?Is it easy to drive?Because ı have a hks twin plate and ı hate this clutch!!!
aps is offline
Old Nov 6, 2005, 10:18 PM
GregGSC's Avatar
the clutch is very close to stock drivability however with that GT30R your planing on getting you might need to go with the stage 2 exedy it will hold alot more power and is just a touch harsher to drive.
Greg
GregGSC is offline
Quick Reply: Exedy Organic Clutch fidanza or Prostreet Online Flywheel and SS Clutch Line Kit
