Redesigned Buschur Racing deluxe FMIC's for EVO8 and 9's
#31
Originally Posted by jbrown
Dave,
A few questions / clarifications:
1. Lower IC pipe is 2" at the turbo and 2.25" at the IC, right? Is it a gradual taper in the hard pipe? or is it just a 2" to 2.25" silicon adapter?
2. What is the diameter of the IC outlet pipe? I have your upper IC pipe which is 2.5".
3. Got any pics of the new setup?
4. I have a Forced Performance White Rabbit, which kit would I need?
#33
Yes, the lower pipe needs changed (outlet on turbo) to go to a GT35R.
The transition from 2" to 2.25" is minor and it is going from small to large which has no negative effect on flow that I can think of. The transition is done in the coupling.
The lower i/c pipe and inlet to the turbo are 2.25". The outlet is 2.5" so it matches the stock plumbing and most aftermarket upper i/c pipe kits.
Which kit you need for the white rabbit. Any of our kits will work. Depends on how you want it to fit, whether or not you want to cut the undertray, if you want lower i/c pipes included in the kit or if you want the largest FMIC you can get.
As for the tube in fin from XS Engineering. I am not answering. I have enough problems speaking my mind about things publically from other vendors as it is.
David Buschur
www.buschurracing.com
David Buschur
#34
So how long will this sale last? Can you give us a heads up before it ends? I would like to make a purchase, but will need alittle time pulling the funds together. Also, are there photos available of the new intercooler and lower pipe?
#37
I have two more of the Deluxe intercoolers left. Then we are comletely out of cores. Once these last two are sold the sale is over.
David Buschur
David Buschur
#39
Not a sale, a permanent price reduction.
The Standards are going to drop to $600.
The Deluxe will drop to $695.
The race FMIC will drop to $695.
I made a very large investment today in a lot of intercooler cores. I had to buy a LOT to get the pricing lower so I could pass this along.
These prices do not include shipping.
David Buschur
David Buschur
#43
David Buschur
David Buschur
David,
$695 for the race intercooler? I'm shocked. I actually called the shop and spoke to Jarrod to see if it was a misprint.... but yes It looks like I'll be ordering up the Race FMIC soon.
Charlee
#44
The intercoolers all work well with the stock turbo. The deluxe includes the lower i/c pipe kit with it. The standard comes with nothing but the intercooler.
The deluxe also sits lower and requires more cutting of the undertray.
The choice is yours. All of us at the shop that have changed our FMIC's have the race on our cars.
David Buschur
David Buschur
