AMS VSR Intake Manifold In stock ready to Ship
Have a AMS VSR Intake Manifold along with the Accufab 75mm throttlebody and all the required wiring in stock ready to ship. These usually are built to order and take 7-14 days to get. We have one ready to ship TODAY.
The AMS VSR intake manifold was developed from extensive engineering, R&D and dyno testing. A large capacity oval plenum acts as a pressure reservoir for each cylinder to draw air at high airflow rates. This allows for better air distribution and airflow compared to the stock intake manifold. The plenum base has large radius air horns to direct as much air as possible into the runners. This Velocity Stack Runner design has been optimized and tested on the dynomometer to give maximum results. The plenum base and head flange are beautifully CNC machined for a perfect fit. Each intake manifold is assembled, welded and pressure tested to over 40psi in a jig. High stress points are stitch welded from the inside to increase burst strength. Everything is included in the intake kit for a hassle free installation. Gaskets, bolts, vacuum fittings, and even a new custom dip-stick tube is provided. The AMS VSR intake manifold is a must for any evo with an aftermarket turbo, allowing for strong clean pulls to 9500+ rpm on race engines.
Gains depend on state of tune and engine specifications. Expect from 10-40whp on street to full race setups.
Included in kit.
# AMS EVO VIII VSR intake manifold
# Throttle body gasket
# Intake manifold gasket
# Mounting hardware
# Vacuum fittings
# Custom made dip stick tube
# Accufab Throttlebody
# TPS Sensor and Harness
$1179 shipped
Order online here
http://store.evostore.com/amsevovivsrv.html
