Tilton and Exedy HD twins
Old Mar 6, 2006, 03:42 AM
  #31
gtlimer's Avatar
PM sent
Old Mar 6, 2006, 08:23 AM
  #32
Chris@nolimitmotors's Avatar
Pm's sent
Old Mar 6, 2006, 04:06 PM
  #33
Yaroslav's Avatar
Man i need EXEDY TRIPPLE CERAMICA HEAVY DUTY. As quickly as possible!
Tell me the price and terms!
THANKS!
Old Mar 6, 2006, 06:59 PM
  #34
Hey Yaroslav,
Give us a call 1-866-381-4618, Triple is only available in SD not HD
Old Mar 7, 2006, 02:06 AM
  #35
Yaroslav's Avatar
Man i need only HD
Old Mar 7, 2006, 09:00 AM
  #36
Steve@NoLimitmotors's Avatar
Originally Posted by Yaroslav
Man i need only HD
Dude, the SD triple will hold a ton of horsepower. As far as I know the 930whp evo in FL is running it. Buschur ran 10.1 on it. It will hold like 900whp and like 750-800 lbs of tq easily. its 3 6 puck discs. The friction surface volume is so immense with 3 discs, your driveline will fail before the clutch does.
ASK me how I know this??? Because in Dec 17th i was running my stock turbo evo down the 1/4 with 380 whp and no matter how hard i tried i could not get the clutch to slip. I had the tires aired down and I would either hook up and bog, or spin all through 1st gear. i finally squeezed a mediocre 1.77 60ft and ran 11.9@117. On my 8th pass I went to launch it again and the gearset literally exploded and blew my bellhousing into 3 pieces. This bent my shifter cables, my input shaft broke, it was nuts. you could pop the hood and see right through the bellhousing and see the purple from the pressure plate. THIS HAPPENED ON THE EXEDY TRIPLE!!!
WHEN ALL WAS SAID AND DONE, THE CLUTCH WAS FINE EXCEPT FOR THE DISC CLOSEST TO THE FLYWHEEL. SINCE THE INPUT SHAFT BROKE AND ENDED UP ON AN ANGLE, IT SOMEHOW SHEERED THE TEETH OFF OF THE DISC. OTHER THEN THAT, THE CLUTCH WAS PERFECT!!!
Old Mar 7, 2006, 10:45 AM
  #37
Originally Posted by freshsrt-4
pm price of the exedy hd. i want it asap!
Thanks again Fresh for the order
Old Mar 7, 2006, 10:46 AM
  #38
Got 2 more Exedy HD's today and more SD's also
Old Mar 7, 2006, 02:15 PM
  #39
Yaroslav's Avatar
Question
YOU`VE GOT TRIPPLE HD?
Old Mar 7, 2006, 02:21 PM
  #40
Sorry I do not have the Exedy HD triple in stock
Old Mar 7, 2006, 02:22 PM
  #41
Dude, read my post, about 5 posts up
Old Mar 7, 2006, 02:58 PM
  #42
Yaroslav's Avatar
This evo uses carbon tripple,Al the same
Old Mar 7, 2006, 03:12 PM
  #43
I think the standard Exedy triple will handle your power no problem
Old Mar 7, 2006, 03:57 PM
  #44
1StealthEvo's Avatar
PM Exedy to 73135. Thanx
Old Mar 7, 2006, 05:30 PM
  #45
Yaroslav's Avatar
Talking
Exedy does not make a HD triple only SD
Oh
And Geo from Titan sells TRIPLE HD
Quick Reply: Tilton and Exedy HD twins
