Pro Street Cam and Cam Gear Special!
We offer to you a great deal for your Lancer EVO 8!!
Two BLOX High Performance cams, in any duration, plus two Pro Street cam gears, for only $549.99 SHIPPED!
All in stock, and are ready to go!
Available combos:
PSBXCM1 $549.99 Specs: BLOX 264 Intake and 264 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM2 $549.99 Specs: BLOX 264 Intake and 272 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM3 $549.99 Specs: BLOX 272 Intake and 272 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM4 $549.99 Specs: BLOX 272 Intake and 264 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM5 $549.99 Specs: BLOX 280 Intake and 280 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM6 $549.99 Specs: BLOX 280 Intake and 264 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM7 $549.99 Specs: BLOX 280 Intake and 272 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM8 $549.99 Specs: BLOX 264 Intake and 280 Exhaust Camshafts, 2 Pro Street Cam Gears
PSBXCM9 $549.99 Specs: BLOX 272 Intake and 280 Exhaust Camshafts, 2 Pro Street Cam Gears
Pro Street Adjustable Evo Cam Gears allow for fine tuning of the camshaft timing to maximize engine performance and allows users to adjust their power characteristics for a myriad of driving conditions. Either with Pro Street cams, OE cams or aftermarket cams, these cam gears will allow for adjustment of the powerband in your Evolution. These cam gears utilize a proprietary anodized Hyperluminum™ alloy with nickel plated gear teeth and 304 stainless steel threads making these cam gears the strongest in the market today.
Precise valve timing can be adjusted and set within the range of ± 12°. Each interval index is laser-etched into the face of the cam gear and 5 locking hex nuts allow for adjustments on the fly. These cam gears are the strongest in the market today! These cam gears are MADE IN THE USA with stringent quality control and the highest of material / parts. These are not gears shipped in from overseas with poor quality and inferior construction like most of the gears on the market today. These gears wont slip and the bolts wont strip like on some of the other gears, and come with a standard one year manufacturer warranty.
Proudly built in the USA.
BLOX High Performance Cams
BLOX high performance camshafts offer the enthusiast increased horsepower and torque over the entire RPM range, through various designs and custom profiles.
All camshafts start off as raw castings sourced from OEM materials. Each is then manufactured using the latest design software and chill-casting technologies. All camshafts are CNC-ground to precise and exacting tolerances and specifications.
Thank you for the orders guys! We will have dyno sheets up soon!
Local customer with BLOX 272/272 combo and Pro Street Cam Gears dyno'd 313whp on a dynojet with 91 octane gas, 20 psi. stock downpipe, stock intercooler, stock turbo.
Gruppe-S
27
Oct 3, 2006 05:10 PM
Yuya@BP
13
Jun 8, 2006 02:14 PM
ProStreetOnline
11
Dec 28, 2005 02:19 PM
ProStreetOnline
Oct 29, 2005 05:52 PM
