Tomei Products (and More) for the Hardcore Enthusiast!!
Hello Everyone,
EDO Performance has returned to the boards; and to kick things off, I am having a huge sale on Tomei products! If there is something you like but do not see below, please let me know and I will get back to you with the best pricing!
Currently In Stock:
Tomei Poncam Set: 683.00 Shipped
(TO-143038)
260 Intake, Duration 260, Lift: 10.7mm
260 Exhaust, Duration 260, Lift: 10.2mm
Tomei Cam Gears: 280.00 Shipped
(TO-152012)
Tomei BOV: 173.00 Shipped
(TO-191186)
Tomei Thermo Oil Killer: 50.00 Shipped
(TO-193040)
Thanks For Looking~
-kev.
Currently In Stock:
(TO-143038)
(TO-152012)
(TO-191186)
(TO-193040)
Thanks For Looking~
-kev.
More Sales...
Power Enterprise:
Power Enterprise Super Strong II Timing Belt = 143.00 Shipped
Power Enterprise Air Impulse II intake system = 147.00 Shipped
Braille Battery
Braille 12v auto battery 165.00 Shipped
The Specs:
- Voltage: 12
- AH: 15
- PCA: 700 Pulse Cranking Amps
- Length: 5.8"
- Width: 3.3"
- Height: 5.9
- Weight: 11.5 lb or 5.2kg
- Use: Road Racing, Drag Racing, Rally Racing, Auto- Cross and Daily Use
-kev
Braille Battery
The Specs:
- Voltage: 12
- AH: 15
- Length: 5.8"
- Width: 3.3"
- Height: 5.9
-kev
Here is what the thermo is good for:
One of the seldom-weak points of 4G63 is rising of oil temperature. It is seen more often in circuit driving. Evo uses thermo switch that will work when the temperature gets around 85 degrees C. Yet when the oil temp is low, it will restrict oil flow to the oil cooler and raise the temperature of oil consequently. TOMEI oil thermo killer lets oil to flow into the oil cooler constantly regardless of its temperature. Still, it is easy to put it back to stock thermo switch in winter to prevent over cool.
Let me know if there are any other questions that I can answer.
bump, 4th of july sale at www.edoperformance.com
check out our major 4th of July sale at www.edoperformance.com !!
