Sun Automobile Ignition Products are now back in stock!!!
Sun Auto Hyper Force System
Hyper Force System is the next generation High-efficiency ignition tuning and strengthening system.
Benefits:
1) Increased engine responses
2) Improved fuel efficiency
3) Improved starting ability
4) Increased Hp/Torque
5) Reliable Ignition Spark Throughout the entire rev range
6) Reduced emissions / Stabilized idling
How does it work?
Normal ignition coils inherently generate back electromotive force (Back EMF refers to a reverse flow of electricity from the coil immediately after ignition). This negatively affects the ignition device in the coil, decreases plug voltage, and negatively affects plug efficiency. Voltage becomes unstable and produces ignition time lag in the next ignition cycle. HYPER FORCE SYSTEM absorbs back EMF, to improve plug voltage and promote complete combustion through 100% coil efficiency. Hyper Force System also eliminates ignition Performance loss due to reduced electrical current under heavy throttle.
With improved ignition efficiency through the entire rev range, torque, acceleration responses, fuel efficiency, and complete combustion can be realized.
Complete Kit including EVO specific harness - MSRP $388, PM For BEST PRICING!~ Free Shipping!! ETA is Mid-Febuary!
Sun Ignition Blade (Spark Plug Cover) - EVO
Sun Automoblie Cyber Speed Valve Cover eliminates negative ions circulating throughout the ignition coils and cylinder head, therefore providing the lowest possible resistance enabling the ignition system to reach maximum potential. Also, when installed in conjunction with the Hyper Force System, you can expect an even better result.
Benefits:
1)Increased Horsepower
2)Increased Torque
3)Increased Fuel Efficiency
4)Quicker Engine Starts
5)Reduced Emissions
6)Improved Throttle Response
7)Eye-Catching Design
Note: Actual effectiveness varies by vehicle and personal drivability
MSRP: $179.99, Speed Element Special Pricing: $162 Free Shipping
Sun Auto Hyper Gauss
If you feel like you need just a little better response for your car with a bit more power without doing a lot to your car, then the Inazma HG (Hyper Gauss) is right for you.
The Inazma HG is a Fuel Regulator that is designed to burn fuel more efficiently. Generally, the fuel particles are clumped together causing the fuel to burn inefficiently. With the magnetic force the Inazma HG generates, the fuel particles are spread apart more evenly helping the fuel to burn much more efficiently which results in many benefits. By harnessing the power of magnetism, combustion efficiency is improved.
Benefits:
Increase in Power
Increased Torque
Better Throttle Response
Increased Fuel Mileage
Reduced Emissions
Quieter Engine Sound
Installation is a breeze. Locate the fuel line going into the engine and install the Inazma HG on the fuel line close to the engine. Secure the Inazma HG with four screws and you're done.
MSRP: $49.99, Speed Element Price: $45 FREE SHIPPING
Sun Auto Hyper Voltage System
The H.V.S. Cyber Speed Version is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. Cyber Speed Version provides both function and stylish appearance; units are designed to fit perfectly for your vehicle, with specialized brackets and three additional grounding cables. The most secure and reliable mounting locations have been determined by our engineering and design team, to ensure an easy installation and excellent performance. An LED on the unit also operates as a system monitor, to alert you when your battery may need service or replacement.
Benefits:
-Increased horsepower
-Increased torque
-Better gas mileage
-Improved throttle response
-Longer battery life
-Improved battery efficiency
-Reduced emissions
MSRP: $269, Speed Element Price: $244 FREE SHIPPING
SUN Hyper Voltage Stabilizer Pocket (Hot Inazma Pocket)
By simply connecting the SUN Hyper Voltage stabilizer pocket to your car's cigarette lighter socket, it cans aid your electrical system to operate at peak efficiency. Air conditioning, stereo, lightings and many other electrical components in your vehicle are constantly creating a load on your electrical systems. These cause fluctuations in voltage which prevents the vehicle from performing at optimum efficiency. The Sun Hyper Voltage Stabilizer Pocket is designed to stabilize battery voltage for enhanced electrical system efficiency, allowing your vehicle to operate at its full potential.
Benefits:
-Work for any 12V vehicles
-Save Gas (Testing shows an average 10% fuel economy increases)
-Reduces Emissions (Testing shows an average 30% reduction of HC)
-Brighter Lights
-Improved Engine Performance
-Reduced Audio Noise
-Compact design for easy fitment
-Easy Plug-in installation
MSRP: $89.99, Speed Element Price: $81 FREE SHIPPING
Sun Auto Hyper Ground System - Cyber Speed Version
The H.G.S. Cyber Speed Version is custom-tailored for the best fit and best performance in your vehicle. Giving your car a more efficient ground will help to pull out its full performance potential. The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals. Designed to exceed stringent OEM specs for heat resistance and durability, these cables are the absolute best available. Cyber Speed Version kits have pre-determined mounting points to ensure the best performance and the cleanest installation.
Benefits:
-Increased torque
-Better gas mileage
-Quicker engine starts
-Brighter lights
-Reduced emissions
-Reduced audio noise
Applications : Subaru Impreza WRX/STi (GDA/GDF: '03+)/ Nissan 350Z (02+) /Mitsubishi Lancer Evolution (03+)
MSRP: $159.99, Speed Element Price: $144 FREE SHIPPING!!
For more info or to place order, please visit our website or simply give us a call at 510-226-8822
Thank you
Calvin
Benefits:
How does it work?
Benefits:
2)Increased Torque
5)Reduced Emissions
Benefits:
Increase in Power
Increased Torque
Reduced Emissions
Benefits:
-Increased torque
-Better gas mileage
-Reduced emissions
Benefits:
-Brighter Lights
Benefits:
-Increased torque
-Better gas mileage
-Brighter lights
-Reduced emissions
Thank you
Calvin
