SLS FMIC Cores
SLS FMIC Cores
Race core: $600
-24x12x3.5
2.5" inlet/outlet
http://store.straightlinespecialties...ba44905414f8e9
Extreme core: $650
-24x12x4
-2.5" inlet, 3" outlet
http://store.straightlinespecialties...roducts_id=263
As usuall all of our products are 100% TIG welded in house and backed by a lifetime warranty.
-24x12x3.5
2.5" inlet/outlet
Extreme core: $650
-24x12x4
on the extreme core, shouldn't the inlet be larger than the outlet?
the hot incoming air is at a higher volume and velocity than the cooled outlet air, so you would need a large tube moreso on the inlet than the outlet.
I'm no physicist, but I do understand the ideal gas law (PV=nRT) and that says that if you lower the temperature and keep the pressure and number of air molecules constant, then you will lower the volume of the air.
Compressor outlet size is more about packaging and A/R control than anything else. Just because the compressor outlet is 2.5" doen't mean that the optimal pipe size is 2.5".
All I'm saying is that if you are going to have an "extreme" intercooler, it should probably have a 3" inlet.
doncarbone
Canadian
13
Sep 10, 2014 09:50 AM
