PE RX6R Turbo Kit,Kevlar belt, 1000cc Inj., Head Gasket/ARP head bolts/HKS Cams/Gears
Power Enterprise
RX6R Turbo Kit
Retail:$5,700.00
![](http://www.fizzautosports.com/images/jdm/jdm_mitsu/PE/4G6320RX6R20baseKit.jpg)
![](http://www.fizzautosports.com/images/jdm/jdm_mitsu/PE/4G6320RX6R350.jpg)
![](http://www.fizzautosports.com/images/jdm/jdm_mitsu/PE/rx6r.jpg)
Lancer Evolution 4G63 RX6R Setup (Pro) KIT, Designed for tuner shops
RX6R, a compact and light weight ball bearing turbine, known for the Formula-1 racing is now available through Power Enterprise, the largest IHI turbo distributor in the world. With engine internal upgrades, it can produce well over 600 wheel HP. The exhaust and compressor housings can separately be selected and matched for each engine specs. The 4G63 RX6R kit can be installed on the vehicle types CN9A / CP9A / CT9A with stock intercooler by fabricating your own inlet and intercooler piping. Large volume fuel pump and injectors are sold separately Setup Kit consist of RX6R turbo, Stainless EX manifold, Outlet pipe & Front pipe, Waste gate valve, Oil lines, Gasket set and hard wares.
Applicable Engines: 4G63(EVOⅣ~EVOⅨ) Power Capability: 450HP~650+HP
Kevlar Timing Belt
Retail: $158.00
![](http://www.powerenterpriseusa.net/products/engine/timing_belt/images/timing_belt.jpg)
The pioneer of Kevlar timing belt
Super strong KEVLAR timing belt was originally developed by Power Enterprise for the tuning and racing industries. The original Kevlar timing belt developped by PWR in 1997 featured 4-times durability against stretching compared to the stock belts gained huge popularity among race engine builders and the most of tuner parts manufacturers. At end of 2006, PWR reintroduced further advanced Kevlar timing belt based on the feed backs sent to PWR from the engine builders of the world. The new Kevlar Timing Belt features Zero stretching, 2.6 times more durable compare to the original PWR Kevlar timing belt and increased haeat resistance, improved in bending flexibility to surpress unwanted osilations. PWR Super Kevlar also improved mechanism of transition stage perfect at fitting into camshaft by compounding nylon fiver in the cog portion. Now It train camshaft uncomplomising exact measure.
1000cc Injectors
Retail: $800.00/set of 4
POWER offers “top feed” and “side feed and the multi spray ports injectors. The 1 & 2 spray port patterns, depending on the engine's intake port system are POWER's unique designs. Multi spray port injectors are designed for higher level of combustion by avoiding atomized fuel hit on the wall of a intake port and flowing in droplets. The injector sprays fuel in 150-200 microns on the back of a valve head without hitting against the wall of a intake port. When the injector size becomes larger the mentioned problem become worse, but POWER developed unique two ports injectors to minimize the inefficiency for many of today's engine applications. The fact is when it's compared to the same amount of fuel passing through the POWER big injectors and the out put horse power for any engine, none of other injectors can compete.
![](http://www.fizzautosports.com/images/jdm/jdm_mitsu/PE/injector.jpg)
Heavy Metal Gasket
Retail: $220.00
Rated at 14,000 PSI!!
Fuel burns at high temperature of more than 2000 and high pressure of 120-150 kgf/c instantaneously in a combustion chamber of a tuned up engine. Under these conditions, a cylinder head gasket must shut off combustion gas completely and seal passages that carry oil and coolant. As turbocharged vehicles with highly powered engines are popular now, head gaskets with grommets are widely used to seal high pressure of combustion gas. Grommets in Power Heavy Metal Gasket are designed to have surface pressure of 800-1000 kgf/c, and beads on the outer frame of a grommet are second sealing to completely prevent instant gas leak caused by knocking. Likewise, grommets coated with molybdenum prevents scratching caused by a cylinder head and a cylinder block, and nitrile gum is used for over the gasket in order to keep high sealing capability.
![](http://www.fizzautosports.com/images/jdm/jdm_mitsu/PE/gasket.jpg)
![](http://www.fizzautosports.com/images/jdm/jdm_mitsu/PE/gas_imag.gif)
HKS
Evo IX MIVEC Camshaft
Intake: 272° duration/10.8mm lift
Exhaust: 272° duration/10.2mm lift
Retail: $699.99/set of Intake and Exhaust
![](http://www.hksusa.com/images_products/camshafts-thumb.jpg)
HKS Cam Gear
Full Duralumin w/ Nickle Plated Gear Teeth
Retail: $225.00
![](http://www.hksusa.com/images_products/L_2613.jpg)
ARP Head bolts
Retail: $190.00
Made of Stainless 300 material which is corrosion and heat resistant making it ideal for high horsepower cars! Rated at 170,000 PSI!!
PM US FOR A GREAT DISCOUNTED PRICE or COMBO!!!
*New York tax of 8.375% will apply to all New York residents*
Thanks,
Fizz
RX6R Turbo Kit
Retail:$5,700.00
Kevlar Timing Belt
Retail: $158.00
1000cc Injectors
Heavy Metal Gasket
Retail: $220.00
HKS
HKS Cam Gear
Retail: $225.00
ARP Head bolts
Retail: $190.00
Thanks,
Fizz
Fizz Autosports
Evo 'For Sale' Wheels / Tires
85
Oct 15, 2008 07:19 AM
Fizz Autosports
Evo 'For Sale' Exterior Styling
63
Apr 29, 2008 12:05 PM
Fizz Autosports
Evo 'For Sale' Suspension / Brakes / Handling
18
Jan 26, 2008 08:13 AM
Fizz Autosports
39
Aug 3, 2007 08:29 AM
Fizz Autosports
38
May 15, 2007 08:22 AM
