*IN STOCK* Okada Projects Plasma Direct Ignition Coils *NEW*
PLASMA DIRECT (PAT)
A revolution in ignition technology!!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Plasma Direct is made to a specific application. Please check Application chart to find the correct model for your car.
Highlights
・100% secondary current (Spark Amperage) increase
・4 Times Spark Energy Increase for the initial spark discharge
・Easy installation. Only replace stock coils to Plasma Direct.
・Compatible with all OEM components
・Compatible with OBD-II (On-Board-Diagnostics)
Mitsubishi EVO
Explosive Discharge Provides
・Top Engine Performance
・Aggressive horsepower
・Dynamic torque
・Lightning Response
・Bombing Turbo Boost
And accord with
・Fuel Efficiency Improvement
・Reduce Emissions
Oscilloscope Data
Comparasion of Ignition Secondary current on the same time scale.
The typical OEM type discharge. The Secondary spark current reaches a maximum of 60mA.
The Secondary spark current reaches over 140mA. Also, the multi spark oscillation is clearly seen.
432.25 Shipped
Okada Projects Plasma Direct Ignition Coils can be used with all Sun Auto products.
As for the HKS Twin Power, DLI 2 is compatible with the Okada Projects Plasma Direct Ignition Coils, but DLI1 is not.
You do not need to change the spark plug to cold type and make larger gap with Okada Projects Plasma Direct Ignition Coils.
Highlights
Mitsubishi EVO
・Dynamic torque
・Lightning Response
And accord with
・Reduce Emissions
Oscilloscope Data
432.25 Shipped
