Sun Auto Hyperforce System - Add 7-10whp Instantly!!! Dyno Tested and Proven!
Sun Auto Hyper Force Systems are now back in stock at Speed Element Performance!
Hyper Force System is the next generation High-efficiency ignition tuning and strengthening system.
Benefits:
1) Increased engine responses
2) Improved fuel efficiency
3) Improved starting ability
4) Increased Hp/Torque
5) Reliable Ignition Spark Throughout the entire rev range
6) Reduced emissions / Stabilized idling
How does it work?
Normal ignition coils inherently generate back electromotive force (Back EMF refers to a reverse flow of electricity from the coil immediately after ignition). This negatively affects the ignition device in the coil, decreases plug voltage, and negatively affects plug efficiency. Voltage becomes unstable and produces ignition time lag in the next ignition cycle. HYPER FORCE SYSTEM absorbs back EMF, to improve plug voltage and promote complete combustion through 100% coil efficiency. Hyper Force System also eliminates ignition Performance loss due to reduced electrical current under heavy throttle.
With improved ignition efficiency through the entire rev range, torque, acceleration responses, fuel efficiency, and complete combustion can be realized.
Complete Kit (including EVO specific harness) - MSRP $388, Please PM me for Best Pricing!!
AWD Dyno Dynamics Test Results:
Here are the dyno graphs of before and after the sun auto hyperforce is installed.
Sun Auto Japan/USA didn't pay us to dyno test their Hyper Force System.
We wanted to test this just to see if it will work like it says after seeing dyno charts in Japanese car magazines (Hyper Rev and Option/Option2, etc)
The test was done on an EVO IX w/ just 2.75 tanabe downpipe and HKS Hiper Exhaust.
There is absolutely no tuning or tweakin' of anything what so ever. Straight plug n play and you gain the power instantly.
Before
After
Thank you!
Calvin
Benefits:
How does it work?
Before
After
Thank you!
Calvin
BLOX Racing Engine Roll Stopper!!!
Improve traction and reduce the front-to-back movements your engine makes while under on/off throttle conditions.
Fits all 2003-up Mitsubishi Evolution 8 & 9 RS, GSR and MR Models
*Light Weight, Strong, and Rigid.
*Traction is greatly improved due to the significant reduction of front-to-back movements while the engine is under on/off throttle conditions; furthermore, it improves shifter feel and on/off throttle response.
Speed Element Introductory offer - $75 Shipped
Please give us a call to order.
Thank you!
Thank you!
Thanks for the Blox roll stopper. Worked wonders for my on/off response and QTP DP clearance issues. If you are considering getting a QTP downpide, this is mandatory on a IX. Most likely an 8 also.(i don't know.)
More vibration in cockpit, but I didn't expect less. I am very pleased with my purchase. Thanks Speed Element. Blox Rox!
