ACL/AEM/BLITZ/COBB/GReddy/HALLMAN/HKS/INJEN/KOYO/PERRIN/PWR/
AEM C.A.R.B Legal Short Ram Intake Kit - 03+ EVO VIII and IX!
The AEM Air Intake system includes turbo air intake pipe, high flow air filter, hose clamps, heat shield and all necessary hardware to install. After installation you can expect the quicker turbo spool, and the turbo will be noticeably louder than stock.
Additional 7-10whp gain can be realized w/ proper tuning.
AEM Short Ram Air Intakes are Available in Blue, Red, and Polished.
C.A.R.B Legal sticker is also included!
MSRP: $274.03, Our price: $235 Free Shipping!
Blitz Induction Cover - 03+ EVO VIII/IX
Introducing a new concept for air filtration - Blitz Induction Covers feature handcrafted T-304 grade stainless steel, designed specifically to fit the factory air box and OEM parameters. By utilizing the LM Stock Replacement Filters and factory air box, Blitz Induction Cover applications reduce intake restriction and provide maximum filtration while retaining valuable torque that can be lost in other applications.
MSRP: $138. Our Price: $125 Free Shipping!
Blitz LM Stock Replacement Filter - 03+ Evo VIII/IX
Utilizing the same filter as the LM Core-type filters, the BLITZ® LM Stock Replacement Filters are designed to reduce intake restriction and provide maximum filtration without sacrificing the stock air-box. Unlike conventional filters made of paper or foam elements requiring oil to maintain filtering capacity, the LM Stock Replacement filter is made of cotton, without any assistance of oil – the oils used to clean such filters gradually disperses into the inlet tracts of an engine, and coats the walls and in particular the air flow sensor, slowly reducing the performance of the vehicle. The BLITZ® LM Stock Replacement is a simple remove and replace application.
Our Price: $46 Free Shipping!
COBB Tuning SF Intake - 03+ EVO VIII/IX
The COBB Tuning SF Intake utilizes our custom design to maintain optimal flow and net the ideal performance. The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems. The COBB Tuning SF Intake system is compatible with Stage 1 and Stage 2 OTS (off the shelf mapping) provided for our AccessPORT ecu tuning device.
Our Price: $115 Free Shipping!
HKS Kansai Service Carbon Fiber Induction Box - 03+ EVO VIII/IX
Kansai Service Carbon Air Duct Set. This kit is designed for higher volumes of cold air, and will greatly increase performance!
Must use HKS Intake kit and Kansai Service or Ralliart Piping Kit with this duct.
MSRP: $540, Our Price: $455 Free Shipping!
HKS Super Hybrid Panel Filter - 03+ EVO VIII/IX
HKS’ high-performance Super Filters are a direct replacement for OE panel filters when a factory airbox is required or preferred. Super Filters feature the same 2-layer wet-type, polyurethane material as in the Super Mega Flow. The filter element is bonded to a flexible nylon frame and offers a price-friendly performance alternative to a full intake system.
Our Price: $37 Free Shipping!
Hallman Boost Controller PRO RX KIT : BLACK or RED
All parts and components of the Pro Series controllers are custom CNC Machined.
The new adjustment system does not require a lock nut or a hex wrench to adjust boost, simply adjust the knob and it stays put.
Also if the knob is adjusted all of the way out it cannot come out of the controller. This new feature and design provides for a perfect overboost system since none of the internals can be lost.
You cannot lose your adjustment knob because of vibration or forgetting to tighten the lock nut like on the old style adjustment knob.
The Pro Series has O-ring integrity for precise control.
Every Pro Series boost controller may be easily upgraded to cockpit control by purchasing a newly designed add-on kit. Of course you will be able to buy it as an Evolution kit with the cockpit control already installed.
MSRP: $115, Our Price: $99 Free Shipping!
EVO Tial BOV - 03+ EVO (w/flange)
For use on turbo-charged and super-charged applications (Paxton, Vortec, etc.). The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve; we believe this is the largest valve available with the highest flow capacity. The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp is anodized and uses Stainless Steel hardware for a long lasting, corrosion-free appearance. The valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance.
Our price: $255 Free Shipping!
Perrin 3port Boost Control Solenoid: 03+ EVO VIII/IX
Factory boost control management relies solely on a flimsy, inefficient actuator. When boost levels are increased over stock, by the use of aftermarket ECU’s, these factory actuators fail to properly meter boost. The resulting spikes, dips and erratic response can not only damage your engine but certainly spoil the performance gains. Enter the PERRIN EBCS!
Constructed from billet aluminum and fiberglass reinforced composites the EBCS, is a true solenoid. It is rated to hold boost pressures in excess of 100 psi and thus far more than any gasoline turbocharged engine will ever see. This product is especially helpful for tuners that have otherwise not been able to utilize boost functions found in many aftermarket reflashes and ECU’s. Avoids the cost and additional tuning of standalone electronic boost controllers.
Available for most factory turbocharged applications as well as a replacement for many aftermarket boost controllers.
MSRP: $94.99, Our Price: $86 Free Shipping!
Perrin Manual Boost Controller - 03+ EVO VIII/IX
Your turbocharged street beast demands a higher level of boost and thus a PERRIN™ Performance manual boost controller is in order! Adds horsepower and torque while achieving a perfect balance of response and boost level. Combined in a “twist-to-adjust” package that incorporates a custom wound internal progressive rate spring and ceramic metering ball for boost management. Applicable to all turbo charged applications.
MSRP: $84.99, Our Price: $79 Free Shipping!
ACL Race Bearings - 03+ EVO VIII/IX
The unique combination of design, metallurgy and engineering come together to deliver what drivers expect from high performance Trimetal engine bearings. Designed to withstand higher RPM conditions.
- Standard Size
ACL Race Main Bearing - 03+ EVO VIII/IX
ACL Race Rod Bearing - 03+ EVO VIII/IX
Our Price: $69 Free Shipping!
ACL Race Thrust Washer Set - 03+ EVO VIII/IX
Our Price: $29 Free Shipping!
PERRIN FRONT MOUNT INTERCOOLER
Once simple look at thephotos above and it is easy to see the VAST difference in shear size ofthe PERRIN Front Mount Intercooler over the OEM one! This is certainlyan ideal case of size DOES matter.
Turbocharged engines rely on the compression of air to make boost. Not only does this process raisethe temperature of the air, but the unit doing it (the turbo) is also extremely hot. While the motor benefits from the increased pressure,far more HP can be gained by cooling that air down to increase thedensity. The factory did a great job of placement of front, but theyare limited by budget when choosing the core material and size. This iswhere PERRIN is allowed to excel!
All PERRIN intercoolers are made right here in the USA using similar core designs used on military aircraft, large diesel applications, ships and the like. Divorcing ourselves from the Chinese sourced cores has allowed us to make more HP, have better quality, yet we have been able to keep costs down tostill offer you a superior product at a more than reasonable cost. Weuse a bar and plate design to the core material. This gives us moresurface area per cubic inch that tube and fin, along with less pressuredrop across the core. Don't forget the cast aluminum endtanks. Reduceweight and increase flow by eliminating restriction. Additionally, in our quality control area, each core is tested at 120 psi, for ANY leaks. If the core leaks in anyway, it is immediately rejected,repaired and re-inspected. When you buy from PERRIN you can be assuredthat your core is of the highest quality.
So what all does thistechnology and quality mean to you? Well PERRIN offers the largestcore, the least pressure drop, the most HP gain over stock (someclients can see more than 30 WHP gain!), supports up to 1000HP, and allof this can be installed at home with simple hand tools. This even fitscompletely behind the OEM bumper skin! No cutting or hacking isrequired.
Backed by the PERRIN Warranty, customer service andtech support this is a real value at this price! Questions? Need asound clip? Just let us know. Happy to help via e-mail, AIM, fax orphone!
REGULAR FMIC - MSRP: $759.99, Our Price: $649 Shipped!
STEALTH FMIC - MSRP: $799.99, Our Price: $729 Shipped!
Injen Aluminum Intake System w/ Full Intercooler Piping: EVO
With an amazing gain of up to 22hp, this kit features a cast multi-stage tuned mid section for volumized airflow throughout the entire power band. Combined with the upper intercooler piping (included), and now the lower IC Pipe as well, the system eliminates hose expansion to increase throttle body response going into boost. Dyno proven performance, not hype! This system will work with the factory Front mount on the Evo or with almost any of the aftermarket units.
MSRP: $550.80, Our Price: $409 Shipped!
Injen Intercooler Pipe Kit Mitsubishi EVO VIII/MR 03-06
The all new Intercooler Piping Kit will accommodate your stock intercooler and give it the added dress up your engine needs. This three piece system easily bolts on to your 2003-2005 EVO VIII and 2005-2006 MR without any modifications and includeds heavy duty T-bolt type clamps.
KEY FEATURES:
- Three Piece design
- T-Bolt type Clamps
- Accommodates Stock Intercooler core
- Completely Bolt On
Note: Will NOT work with Factory Air Box
MSRP: $475.50, Our Price: $369 Shipped!
Koyo high performance radiator - 03+ EVO
# Fully polished to a mirror finish
# Provide 20% to 30% more cooling than standard radiators
# Handles high revving, high performance motors
# Perfect for Turbo Charged, Super Charged & Nitros Oxide equipped engines
# Made from aircraft quality aluminum and Heli-arc welded, cores are NOCOLOK-brazed
# Koyo Radiator is on the cutting edge of technology and design with Japan's largest automobile manufacture
# Custom built OEM fit - All Koyo Radiator cores and tanks are specifically designed and built for each application. No universal fit parts are used.This ensures proper fit, just like your original equipment!
MSRP: $499, Our Price: $425 Shipped!
PWR Aluminum Radiator: 03+ EVO
PWR alloy radiator is a direct bolt in. Full aluminum end tanks and core. This enables maximum cooling and power efficiency. Utilizing all stock mounts, there is no modification necessary. Add this nice improvement for additional horsepower and cooling. Its a well known fact that the 4G63 motor runs really warm, especially when running more HP and higher boost. This stock fit radiator is 100% Tig- welded Aluminum and uses a furnace brazed core giving 30-35% more efficient cooling!
PWR 40MM - Our Price: $629 Shipped!
PWR 57MM - Our Price: $649 Shipped!
PWR Front Mount Intercooler: 03+ EVO
PWR Intercoolers are manufactured using the highly efficient and light weight tube cores are individually made by hand and the tubes cut to the required length. The EVO intercooler uses the OEM piping so there is no need for aftermarket piping but is useable with most aftermaket pipe kits.
The PWR measures in at : 23.5"x12" x3" for a total 846 cubic inches.
The intercooler core is rated for a whopping 1320cfm flow capacity and has a 282 cubic inch surface area with less then 1psi air pressure drop increasing power output significantly! PWR's extruded tubes and rounded on the ambient air side to allow for smoother cooling air flow for additional efficiency.
Our Price: $899 Shipped!
Samco Intercooler Hoses - 03+ EVO
Time to retire your factory Intercooler hoses and radiator hoses!!!! Did you think these will last you forever??
Samco Hoses are 4x more durable compared to OEM hoses. Built to handle extreme heat and cold other hoses cannot. Specially manufactured to insure OEM fitment while also having the ability to hold extreme PSi standard rubber hoses cannot.
EVO VIII - MSRP: $299, Our Price: $275 Shipped! (Available Color: Black, Blue, Red, Yellow)
EVP IX - MSRP: $334.86, Our Price: $295 Shipped! (Available Color: Black, Blue, Red, Yellow)
Samco Hose Radiator Hose Kit for EVO VIII and IX
EVO VIII - $109, Our Price: $99 shipped!
EVO IX - $138.58, Our Price: $129 Shipped!
Greddy Ti-C Exhaust System and Packages - 03+ EVO
GReddy Racing Ti-C Cat-back Exhausts combine the design, looks and flow of our Full Racing Titanium systems with the durability, deep sound, value and large application list of our other Stainless Steel street systems. This fusion of aggressive styling and practical construction, makes this the logical choice for both Race and Street Enthusiasts. The systems are comprised of a Titanium heat-treated tip, polished stainless steel muffler, unpolished stainless steel piping. It improves high and mid-range performance while still allowing for suitable sound levels.
MSRP: $625, Now On Sale - $500 shipped!!
* Greddy Ti-C Package #1 - Add Speed Element 3" Test pipe for Only - $599 free shipping!!!
*Greddy Ti-C Package #2 - Greddy Ti-C, Speed Element 3" Test Pipe and Perrin 3" Downpipe (clears EVO IX ACD) for Only - $829 Free shipping!!!
Greddy Ti-C Exhaust System and RRE Rally Cat COMBO
Road Race Engineering Rally Cat
3" resonated test pipe that looks like a working catalytic!!
This item is for off-road use only.
Greddy Ti-C & RRE Rally Cat COMBO -$750 FREE SHIPPING!
Disclaimer: Parts listed above have been designed & are intended for off-highway or racing use only.
3"gaskets and mechanical o2 CEL fix are included
Please give us a call to order!!
ALL PARTS ARE IN STOCK AND READY TO SHIP!!
Thank You!
- Standard Size
KEY FEATURES:
Thank You!
Speed Element
EvoX 'For Sale' External Engine / Power
May 25, 2010 05:45 PM
Speed Element
Jun 4, 2009 05:16 PM
Speed Element
55
Mar 18, 2008 11:14 AM
Speed Element
Feb 13, 2008 02:34 PM
Speed Element
Jun 28, 2007 11:01 AM
