MAPerformance Stainless TiAL MVS and O2 Eliminator Downpipes!
![](http://www.maperformance.com/gallery/pictures/Modifying.gif)
Please contact us for unbeatable pricing on these great options!
AIM - Adam At MAP
Phone - 763-545-3800
Email - Adam@maperformance.com
PM - Click CLICK HERE TO PM US!
Stainless Steel TiAL 38mm MVS O2 Eliminator!
![](http://www.maperformance.com/gallery/pictures/evomvs2.jpg)
![](http://www.maperformance.com/gallery/pictures/ICS%20Dyno_medium.jpg)
![](http://www.maperformance.com/gallery/pictures/ICS%20Dyno%202_medium.jpg)
In this installment of our never ending quest for the perfect Evo downpipe we have utilized the new, ultra-compact 38mm MVS wastegate from TiAL Sport. Remove the internal wastegate flapper from your turbocharger, enlarge the wastegate discharge and bolt up one of these bad boys for the best boost control and elimination of boost creep available! Click here for more information and pictures!
Stainless Steel O2 Eliminator Downpipe!
![](http://www.maperformance.com/gallery/pictures/evosso2e.jpg)
These bad boys are made from 304 stainless steel and 100% made in the USA
![US Flag](https://www.evolutionm.net/forums/images/smilies/smillie_flag.gif)
Affordable Mild Steel O2 Eliminator Downpipe!
![](http://www.maperformance.com/gallery/pictures/3inchdp2.jpg)
With no difference in design of the above downpipes. This bad boy was created to be easy on your pockets, while still packing the same punch as the above. Not only can we make the O2 eliminators with external dump in mild steel, we also can make the TiAL 38mm MVS downpipe in mild steel! (Just use the contact methods above for pricing)
For any other information click HERE!
AIM - Adam At MAP
is this for the stock turbo? I have a pt 50 trim that im looking for a downpipe for. It is the 5 bolt turbine housing. I have a manifold that has a wastgate flange but i need to find a downpipe that recirculates the wastegate.
So is it a possiblity to just get the recirculated pipe off the stock wastegate or does it have to have the external wastegate to have recirculation? The main reason I ask is i have been wanting for some time to go back to ecu boost which uses the stock solenoid and wastegate... Could you do ecu boost with an external wastegate??
We have this pipe:
In recirculation form. Pricing and info can be found here:
http://www.maperformance.com/map-int...ution-8-9.html
I'm not to sure on the ECU boost. We are using a GM boost solenoid to control the EWG on our shop EVO with no issues. I'm sure something can be had.
