Magnus Cast Manifold - Lowest Pricing!
Vivid Racing has the lowest pricing available for the the Magnus Intake Manifolds!
Magnum V5 Cast Aluminum Intake Manifold EVO VIII, IX 03-07
Magnus designed this one from a fresh sheet of paper. Out of over a dozen prototypes, endless testing and perfecting, the Magnus Cast Intake Manifold was born. They applied their years of experience from crafting thousands of sheet metal intakes and once again have raised the bar for power and quick response. By applying a unique design and a massive 5L plenum, this cast manifold means big power and big power sooner!
Cast in A356 Aluminum with a wall thickness of 3/16"; the Plenum shape features a varying contoured tapered profile at a volume of 5 liters. The runners themselves are completely revolutionary in their design; featuring an integrated velocity stack that gradually transitions into the head port profile. It was designed entirely against the shape of the original cylinder head port taking advantage the 10 degree port entry of the EVO head maintaining un-interrupted laminar flow. The Magnus Cast Intake Manifold will work with throttle bodies from stock right up to 100mm and have seen consistent gains from 30 awHp to 52 awHp with varying setups. Transient boost response is exceptional and it can bolt together in a stock location if required while still being able to be used on a full blown race application.
V5 Cast Aluminum EVO Intake Manifold Features:
PM or email for pricing, and
CALL FOR ABSOLUTE LOWEST PRICE!
- 2 years of research and development
- Cast from A356-T6 Aluminum Alloy
- High quality casting gives a superior surface finish
- Enhanced flow dynamics utilizing CAD Modeling & CFD simulation
- Flowbenched and dynamically tested
- Dynotested proven up to 50 HP over stock
- Ability to flow 100 lb/min (1000 HP) of air at 60PSI and maintain equal flow
- Install in stock location with clearance for original battery (with adapter)
- Install kits feature dipstick tube adapter, remote map sensor boss for use with factory ECU’s
- Stock turbo gains up to 40HP
- 15 degree entry to the throttle body facilitates intercooler plumbing
- Can be configured for 8 injector setup
- Fits factory fuel rail or Magnus high flow fuel rails
- 5L plenum with contoured velocity stacks molded into the floor for huge top end and minimal turbulence
- Magnus Quality and Lifetime warranty
