EVO VIII-IX 75 MM Throttle Body
EVO VIII-IX 75 MM throttle body is designed in such way that it will use stock EVO VIII-IX idle control and TPS. Throttle body has 88 MM bolt holes pattern (Mustang 5.0) and will fit all aftermarket intake manifolds designed for Mustang 5.0 throttle bodies. Our EVO VIII-IX 75 MM throttle body comes as a kit including stock manifold adaptor plate and 60 MM hose adaptor (for those that want to use it immediately with stock intake pipes). Kit also includes 75 MM hose adaptor and all mounting hardware. Throttle bodies are CNC machined of billet aluminum. Parts are available in natural aluminum and black anodized finishes. Increasing diameter to 75 MM gives almost 56% increase in throttle cross section area over stock throttle body. Replacing stock throttle body with our new 75 MM (even with stock pipes and turbo) will give you a few additional HPs and greatly improve engine response. Replacing stock throttle body with our 75 MM throttle body and replacing intake piping with larger diameter (75 MM) gives limitless possibilities of increasing engine power. All parts are manufactured to our legendary high quality standards and backed up by our warranty.
We have Mustang 4.6 (BBK small bolt pattern) adaptor kits available in natural, red anodized and black anodized finishes.
We are also introducing new adaptor kit for Q45 bolt pattern. Q45 adaptors are available in natural, red anodized and black anodized finishes.
Both kits include special gasket and all necessary hardware.
Boomba 75 mm Throttle Body can be bolted to almost any available stock or aftermarket intake manifold.
Check our website for pricing.
We got almost 12 Hp power and 13 ft-lbs torque gain.
