Fuel Components and Kits, AVID, Megan, Tial, Turbosmart, Mishimoto & More!!
Old Oct 21, 2009, 10:22 AM
  #31
SBR INC's Avatar
Originally Posted by evoracingstar
pm price for avid motor mounts 5spd evo9 06076 any chance have them in black?? thanks
I can send you some mounts and a sharpie
PM'd you.
SBR INC is offline
Old Oct 21, 2009, 11:14 AM
  #32
SBR INC's Avatar
Snow Performance Safety Injection
The ultimate safeguard for your engine. Snow Performance SafeInjection is a watchdog that always monitors the system output flow. Designed as an add on to the Boost Cooler water/methanol injection system, Snow Performance SafeInjection provides for a safe tune in those instances where no injection is present and an aggressive tune is utilized. This system reduces boost and/or timing anytime injection quantity goes below the set point regardless of the reason (ran out of fluid, clogged line, etc.). This sets your vehicle into a “safe mode” making your tune instantly conservative for the ultimate in safe water/methanol injection.
Be sure to check out our boost control options: Wastegate Solenoid, Boost Controller Bypass Relay, Bypass Valve Solenoid.
What does this mean in plain english? This means that you can run meth/water injection with the piece of mind knowing that you have a safe guard against malfunction or lack of fluid.
REMEMBER, WE WON'T BE UNDERSOLD!
SBR INC is offline
Old Oct 22, 2009, 06:51 AM
  #33
SBR INC's Avatar
Snow Performance Meth Kit - Stage II MAF Kit
The Snow Performance Stage 2 MAF Boost Cooler kit uses the 0 to 5 Volt output signal from the Mass Air Flow sensor on many fuel injected vehicles. This means that any vehicle with a MAF (with a 0-5V output signal) can use this kit, whether they are naturally aspirated or forced induction. If the application is forced induction, it can be used with very fast-spooling turbos, or positive displacement blowers. It is easier to set up with the positive displacement blowers with a MAF signal because it is more progressive in nature vs. the boost pressure signal on those applications. This allows for the most accurate injection possible over the widest range. The result is the most power and driveability possible. Now with Lifetime Warranty – please see details.
When you run your meth based on a MAF signal, you can rest assure that you're getting the ideal injection rate!
This is just ONE of the many options that we have for meth/water injection! Get with one of our reps for more info.
SBR INC is offline
Old Oct 25, 2009, 01:39 PM
  #34
GdotRegEvo9's Avatar
pm price for tial bov and wastegate for evo 9 thanks
GdotRegEvo9 is offline
Old Oct 26, 2009, 07:10 AM
  #35
SBR INC's Avatar
which BOV buddy???
SBR INC is offline
Old Oct 29, 2009, 03:16 PM
  #36
SBR INC's Avatar
tomorrow will be the last day on most of these deals folks! Take advantage of the savings while they are offered. If there is something that you're looking for that isn't on this list, please let us know and we'll do anything we can to earn your business.
SBR INC is offline
Old Nov 5, 2009, 08:29 PM
  #37
binky's Avatar
Hey Marti-
Any word when my Avid motor mounts will be here?
Thanks!
-Mike
binky is offline
Old Nov 6, 2009, 09:34 AM
  #38
SBR INC's Avatar
getting the tracking now!
SBR INC is offline
Old Nov 6, 2009, 11:25 AM
  #39
SBR INC's Avatar
Mishimoto back on the shelf!
SBR INC is offline
Old Nov 6, 2009, 01:01 PM
  #40
binky's Avatar
Hey Marti
Any updates??
-Mike
binky is offline
