AEM or Perrin Water / Methanol Injection Kits
Hello,
HOW IT WORKS
Once the AEM Water/Methanol Kit is installed, a boost-dependent, variable-flow progressive controller allows the user to determine the amount of water/methanol mixture (up to 50%) to feed into the inlet stream from the fluid reservoir. The controller commands a high-pressure, recirculation-style 150-PSI pump that delivers the mixture. Overall flow adjustments at the inlet are made via one of three different-sized jets (included) that are designed to match most engine power requirements.
RECIRCULATION-STYLE PUMP
AEM's recirculation-style pump offers improved performance, reliability and a much smoother, quieter operation when compared to older switched-style pumps. With the use of a new internal bypass design, AEM's upgraded pump eliminates erratic on and off switching/pulsing and ensures consistent fluid delivery for optimum performance. With durability and reliability in mind, AEM has designed the pump with a Santoprene diaphragm and EPDM seals to withstand the harshest of alcohol mixes.
BOOST SAFE!
All AEM Water/Methanol controllers include a Boost Safe feature. This feature allows users to retard timing or reduce boost via a ground output if the system runs out of fluid or detects a controller error, ensuring fail-safe operation of the engine whether the system is engaged or not. Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, internal controller diagnostics and an LED dash light to warn of low fluid level or error codes (including short circuits.
KEY FEATURES
Universal kit includes everything you need for installation
Boost Safe” feature lets you retard the timing or reduce boost via a low side output if the system runs out of fluid or detects a system error
Recirculation-Style, controller-driven 150-PSI pump provides boost-dependent variable flow
One- and five-gallon tanks with integral fluid level sensors available
LED dash light included for system status and low fluid warning
Methanol compatible (up to 50% in solution with water)
Includes two different-sized jets to match your power requirement
AEM #30-3001: 5 Gallon Kit $395 shipped to lower48 States.
AEM #30-3000: 1 Gallon Kit $395 shipped to lower48 States.
PWI-2 Water Injection System
Perrin #ASM-ENG-901: $499 shipped to lower48 States.
PWI-2 Progressive Water/Methanol Injection System
The process of compressing air to create boost and power, has a byproduct of heat. Heated air lacks the density to make higher horsepower, increases detonation and forces the ECU to pull timing. All of which reduce the power you are looking to create. In order to combat this heat, your turbo car comes with an intercooler to keep the temps in check. These are not good enough for high HP applications and is the reason why we make our larger intercooler upgrades. We are somewhat limited by the physical restraints of the vehicles' size and by the quality of fuel offered at the pump. Yet, high horsepower engines demand additional cooling and detonation control, which is where water/methanol injection come into play.
More info: http://perrinperformance.com/products/show/691
Thank you.
HOW IT WORKS
BOOST SAFE!
KEY FEATURES
Thank you.
Yes sir:
Water/Methanol Injection 1 Gallon Tank
30-3011 $106.52
Water/Methanol Injection 5 Gallon Tank
30-3010 $187.50
http://www.aempower.com/ViewCategory...CategoryID=120
Mellon Racing
EvoX 'For Sale' External Engine / Power
396
Nov 28, 2014 06:42 AM
4WS Tuning
116
Oct 21, 2011 03:08 AM
Mellon Racing
Feb 22, 2011 01:56 PM
maperformance
Sep 7, 2010 01:39 PM
teamturbo
Aug 24, 2009 03:19 PM
aem, controller, evo, give, horsepower, hp, injection, kit, meth, methanol, perrin, progressive, pwi2, system, water, watermethanol, works
