**TOMEI goodies in stock** TOMEI
Hi Guys...
got some Tomei goodies in stock... As Always PM me for pricing!![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
![](http://www.tougefactory.com/ebay/tomei.jpg)
Tomei 4G63 Evo 7 - 9 Oil Thermo Killer
One of the seldom-weak points of 4G63 is rising of oil temperature. It is seen more often in circuit driving. Evo uses thermo switch that will work when the temperature gets around 85℃. Yet when the oil temp is low, it will restrict oil flow to the oil cooler and raise the temperature of oil consequently. TOMEI oil thermo killer lets oil to flow into the oil cooler constantly regardless of its temperature. Still, it is easy to put it back to stock thermo switch in winter to prevent over cool.
MSRP: $60.00
![](http://www.tougefactory.com/ebay/tomeioil2.jpg)
![](http://www.tougefactory.com/ebay/tomeioil1.jpg)
![](http://www.tougefactory.com/ebay/tomeioil3.jpg)
Tomei BOV Evo 7 - 9
Stock blow-off valve of Evo is equipped with the function that relieves the boost pressure if the boost goes up too much at the time of accelerator-on. Therefore, the boost of Evo is not raised more than fixed boost pressure with stock blow-off. But, on the other hand, it will become the cause of turbine blow if the blow-off valve is removed. As for a TOMEI blow-off valve, only the boost pressure relief function has eliminated while the turbine protection function is left. Moreover, since we applied a bypass type instead of an air release type, there is no worry for engine stall or the deviation of a fuel control. It is an item indispensable to tuning of 4G63 by any means.
*Perfect for anyone looking to upgrade the weak plastic Evo 8 bov or anyone with Evo 9 metal Bov looking to go with high boost!*
MSRP: $210.00
![](http://www.tougefactory.com/ebay/tomeibov1.jpg)
![](http://www.tougefactory.com/ebay/tomeibov2.jpg)
![](http://www.tougefactory.com/ebay/tomeibov3.jpg)
![](http://www.tougefactory.com/ebay/tomeibov4.jpg)
***NEW*** NEW***
MSRP: $160.00
![](http://www.tougefactory.com/ebay/tomeievocover1.jpg)
Tomei Type-S adjustable fuel pressure regulator
MSRP: $120.00
![](http://www.tomei-p.co.jp/_2003web-catalogue/image/pic/fuel_pressure_regulator/type_s_big.jpg)
Tomei Type-L adjustable fuel pressure regulator
MSRP: $180.00
MSRP: $60.00
Tomei BOV Evo 7 - 9
MSRP: $210.00
***NEW*** NEW***
MSRP: $160.00
MSRP: $120.00
MSRP: $180.00
![](http://www.tomei-p.co.jp/_2003web-catalogue/image/pic/fuel_pressure_regulator/type_l_big.jpg)
