Super Fuel THREAD!
Super Fuel THREAD!
Fuel delivery seems to be bigger and bigger every day! We get tons of calls every single day about injectors, pumps, filters, rails and more! I figured, why not just make one thread with our fuel products so that we can offer some great stuff at great prices!!!
Keep in mind, this isn't even everything and we'll be updating it all the time with even more!!!!!
Slowboy Racing Injectors! 650-1600cc
Our injectors are 100% drop in and come completely flow tested!!! They are great injectors at great prices!
Slowboy Racing Injectors - 2000cc
Step it up to the big boys! Drop in, with plug and play clips!!!!
Tons of great more fuel products, coming up!!!!
Fuelab Fuel Goodies!
Fuelab is one of our very favorite fuel component manufacturers! These are all very high quality products! Check out some of the great Fuelab Products that we have available for you!
Fuelab 515 Series FPR
FUELAB 515 Series Fuel Pressure Regulators are designed with performance and flexibility in mind. They accept port style and non-port style union fittings without interference. Several configurations are available, supporting carbureted applications as low as 1 PSID to fuel injected applications up to 125 PSID. The 515 Series Fuel Pressure Regulator has a -6AN return port located on the bottom.
Fuel Pressure Regulator Features
Fuelab 828 Series Fuel Filter
FUELAB In-Line Fuel Filters keep your engine running clean. They feature male AN / 37º Flared fitting end caps, so you can attach them directly to other fuel system components*. Also featured are machined internal radii for minimal pressure drop. For greater flow capacity and increased filtration the larger 828 Series Fuel Filter is equipped with a 5 inch element.
Fuel Filter Features
Fuelab Prodigy Fuel Pump
FUELAB has taken Fuel Delivery to the next level… Digital. Prodigy Fuel Pumps are the automotive aftermarket’s first and only speed controllable DC brushless driven fuel pump. Fuelab’s award-winning, patent pending designs offer improved durability, substantially higher efficiency, and lower current draw. With digital fuel delivery you get unheard of electro-mechanical efficiencies in a package half the size of competing pumps. Five models are available ranging in performance levels; with flow rates up to 200GPH and operating pressures up to 125PSI.
Pump Features
- Two -6AN or -10AN inlet ports and one -6AN return port
- Gasoline, diesel, methanol, and ethanol fuel compatible
- Billet Aluminum with anodize per military MIL-A-8625, Type II
- Fine thread pitch for precise pressure adjustment
- Versatile mounting bracket and stainless steel hardware
- 1/8” NPT gauge port with plug for external pressure gauge
- 1/8” NPT pressure reference port with barbed fitting
- Backed by a 2-year limited warranty
- Less pressure drop (works great as a pre-filter)
- Greater flow capacity
- Increased filtration capacity
- Reduced maintenance frequency
- -6AN, -8AN, -10AN or -12AN male inlets and outlets
- Includes low profile saddle clamp mounting bracket(s)
- Replaceable or cleanable filter element
- 200 PSIG maximum pressure rating
Pump Features
- Only in line pump compatible with gasoline, diesel, methanol, and ethanol
- High efficiency sling vane positive displacement pump
- Special housing shape for extremely quite operation and steady pressure
- Carbon 9-vane construction with pressure balanced rotor for high reliability
- Lightweight super-efficient dc brushless motor reduces current draw
- Low mass rotor for high speed reaction to changes in speed and flow
- Powerful high flux density Neodymium rare earth magnets
- No motor brushes to wear out or corrode (low-Sulfur diesel, no problem)
- Wet motor design, no dynamic shaft seals that can wear
- Internal speed controller for variable flow operation
- Accepts 0-5 Volt signal for speed control
- 12 to 16 volt vehicle electrical system compatibility
- No expensive voltage reduction/pulse width modulation controllers required
- Continuous duty–motor speed can be adjusted for street or strip fuel demand
SBR INC
Nov 30, 2009 09:15 AM
SBR INC
13
Nov 9, 2009 09:38 AM
SBR INC
Nov 6, 2009 12:24 PM
SBR INC
Aug 24, 2009 12:00 PM
